Good d44 U-joints?
Discussion in 'The Garage' started by atlantak-5er, Feb 3, 2004.
  1. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I know about the CTM U joints but they cost like $180.00 ea! Who makes some U joints for the d44 that are better than stock but don't cost an arse load? The reason I ask I am putting in a front locker and want to beef up my axles some. Also anyone use the Warn hub Fuses? They sound like a good idea, what do you think?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running Brute Force u-joints in my D44
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
  5. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Thanks. Are the 760 X joints really stronger than my stock ones?
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes they are supposedly stronger. They are a cold forged joint I believe which makes it a stronger cross section than the 297-x. I think the cross section is also larger... At $17.50 ea, you cant go wrong.. Your next step would be the heat treated and Cyro'd 760 from Longfield and then from there the CTM's...
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    The correct # for the 760's is: 5-760x
    I have done some seraching on POR and they say they're about 15% stronger than the 297's. The dimensions of the 760 are a little smaller though, but being they are cold forged ratehr than hot forged, makes them stronger. In a post on POR Jesse at High Angle commented that he feels the cross section is stronger, but the caps are the same strength..
    HTH...
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI
    Locker and Warn Fuse, are not compatable !
    Something about the shock load when the fuse let's go.
    good luck
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    the only lockers you can run with hub fuses is the ARB, welded, or spool.
    Harley
  10. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Darn that sucks, I guess the weak link will still be the u-joints which can fubar your axles when they go!
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The fuses can still blow a yoke as well. I am gonna run fuses when I put in my mini spool and see just how strong the 760's are. I am experimenting with the fuses them selves as well. If you remove a pair of opposing teeth the fuse should let go sooner. We'll see though. /forums/images/graemlins/dunno.gif Either way you will blow a locker, detroit or otherwise. An ox and e-locker are more of a selectable spool in their design and act same as a spool when locked.
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I run fuses and I have blown one too.
    Man it sounded like I busted a shaft when it let go.
    BAM! Then 10min later I was ready to roll /forums/images/graemlins/waytogo.gif
    just needed to make sure I got all the teeth out of the hub first /forums/images/graemlins/thumb.gif
    My D44 is stuffed with all the goodies out there. I am not locked I run a Power-lock (preloaded posi). I carry extra hubs too just incase when a fuse lets go it may granade the hub too?? /forums/images/graemlins/peace.gif
  13. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i bought a set of the spicer 5-760x's and have been having good luck so far. they may be just as strong as the stock ones, but they have one hell of a better seal design verses the stock one. another thing i did was weld the caps to the yoke. i have had more problems popping caps off.
