Good D60, Bad D60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OneLeft, Aug 29, 2001.
  1. OneLeft
    OneLeft 1/2 ton status
    Aug 14, 2001
    111
    Colorado USA
    I know the subject line sounds like some kinda twisted adult entertainment that only a sicko would...Um...anyhow...
    I am thinking about getting a 3/4ton parts truck. The one I was told about has a D60, I think, and some other desireable parts. My guestion is, since I dont know what to look for....are there good D60's and bad D60's?
    OneLeft
    http://coloradok5.com/gallery/OneLeft
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If it is 3/4 ton, be carefull. Stock only had 10 bolts or D44's. A D60 may have been swapped in. Look at the passengers side spring mount/perch. If it has 2 bolts and a u-bolt, it is a 60. If it has 2 u-bolts its a 10 or D44. Good luck, I hope you get a 60. To my knowledge, any Chevy D60 should do. There were some version that had ball-joints instead of kingpins but I believe that was only for Ford or Dodge. Wes (thatK30guy) might be of better assistance.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  3. OneLeft
    Aug 14, 2001
    111
    Colorado USA
  4. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    There are some closed knuckle ball joint looking D60's that you DO NOT want. I don't know if GM used any of those though.
    Also, like Leadfoot said, 3/4 ton GM's came with D44 in the front.
    Another sign, is the bolt pattern holding the steering arm on the axle. A dana 60 has four bolts in a square pattern, anything less has three bolts like your blazer.
    Good things come in small packages. Good things come to those who wait. So, if you're waiting for a small package, that must *really* be sweet.
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    "There are some closed knuckle ball joint looking D60's that you DO NOT want. I don't know if GM used any of those though. "
    Please elaborate. I am looing at getting a military D60. Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dawson, GM has never used a 'closed-knuckle' axle. The D60 front was started in '77, so, everything from then was already 'open-knuckle'.
    What is this military D60 you are looking at? Is it just the axle, or a complete vehicle? If its just the D60 axle itself, it more likely will be one off the M-series trucks. Those 1 1/4 ton's are pretty much the same as the civilian model K30's. If you are looking at the Kaiser Jeep's, then those are the closed-knuckles. If you are looking at this axle, pass on it, no matter how good the deal is.
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, you are looking at a 3/4 ton truck, and it is said to have the D60 front on it. Be very careful. 3/4 tons came with D44's and 10B axles. The D60 was only available on the 1 tons.
    I have heard of the HD 3/4 tons, but NEVER once have I seen a D60 on one. [​IMG]
    The best way to check is by the explainations as told by the previous posts.
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Dawson,
    The two 60's that I just received are exactly as Wes has described and are off of a mid 80's CUCV.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  9. OneLeft
    Aug 14, 2001
    111
    Colorado USA
  10. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    The axle is off a 1 ton military p/u so am I in the clear? Whats the deal w/ the 35 spline outers I keep hearing about? Thanks!
    Dawson
    Raleigh, NC
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nope! Thats a good thing!! At least the 14FF rear will bolt right up into a Blazer!!! If you had a 'true' 1 ton 14FF, then you would have had to relocate the spring perches and shock mounts. But being the truck is a 3/4 ton, and the fact it has a D60 under it, you found a great buy!!! [​IMG]
    As for 'good/bad' on the D60, there are none!!! Everything is good. The only 'bad' thing they have are the 'weak' outer shafts which have 30 splines. But those can be swapped out for some beefy 35 spline shafts and new lock out hubs.
    Just about everything else on those axles are bulletproof and nothing else needs to be changed. Nothing else was ever changed from the year it came out up to the final year it was made, which went from '77 to '91.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dawson, the p/u version is the great truck you are looking at. Buy it!!! Those D60 from the CUCV vehicles came out with 4.56 gears and some had Track Locks.
    The 35 spline outers are just an aftermarket add-on to beefing up a 'weak link' on the stock 30 spline outer shafts. They are somewhat like 40% (I think) stronger than stock. The splined end at the lock out hub part on the 30 spline shaft 'necks' down, where as the 35 spline shaft is a solid straight shaft with no taper.
    ORU, Dynatrac are some of the few who make or sell these 35 spline outer shafts.
  13. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Its just the axle. Guy I know found another guy who has about 20-30 of them, but doesn't know what he has. I am picking up one of them. The guy I know is buying all of them. He thinks he can sell all of them locally, but if he doesn't, and wants to ship them, I will pop them up here. I should get it from him on Sunday. How much do the 35 spline outers cost? Are they really worth it? Thanks!
    Dawson
    Raleigh, NC
  14. OneLeft
    Aug 14, 2001
    111
    Colorado USA
    Sweet. I already have a 14FF in the rear, so, and extra one never hurt anything, right?! I hope it turns out to be what they claim, but ya never know I guess.
    OneLeft
  15. OneLeft
    Aug 14, 2001
    111
    Colorado USA
  16. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Dawson: That guy with the axles you are talking about......does he hav 20-30 D60's or what. If they are D60's with kingpins, I'll drive up and get one. Let me know the specs (ratio, new or used, etc.....)
    Chris
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dawson, where is this guy with 20-30 of these axles?
    I want to buy some too.
  18. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Wes he is in Raleigh, NC if he wants to ship them I will put them up here.
    Dawson
    Raleigh, NC
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, thanks, and cool beans!! [​IMG]
    PM me with a price for each axle. [​IMG]
  20. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    if he's selling for a good price i'll pickup and delivery some on my way home! what kinda money is he asking for 'em?
    Justin
