Good day at The Truck Spa
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Burt4x4, Feb 3, 2006.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I just got back from putting my K5 on a Dyno,
    Here are some numbers:
    When I first got there:
    WOT - Max Power = 265.18 ,
    MaxTorque = 361.30 ,
    Air/Fuel Ratio @ WOT = 16.6 - 17.1 ( I found out this is REAL BAD )
    When He was Done:
    Max Power = 285.44
    Max Torque = 389.63
    Air/Fuel @ WOT = 12.1 - 12.6 ( Now sitting in the sweet spot )
    All in all it was a good experiance seeing my rig on that dyno howlin like a mad dog at WOT.Soory no pics. My wife has the cameras on her out of town trip....
  2. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    When the cat's away the mice will play!!! Enjoy your freedom, we all need alittle.
    Nice numbers!!!!!! Later J.
  3. Burt4x4
    6,854
    You are correct...I haven't even done a thing on the Honey-Do-List:D
    She gets home on Sunday so maybe I can get caught up...hahaha NOT:D
    Ok the beer talkin...shhhh don't turn me in hahhaaa
    Later
    Burt
  4. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Honey Do
    Luckily mine is understanding, the list is so long now I can't even see the end of it. My main job around here is to kill bugs and keep the mice away, which I do very well and that lets me play with my truck!! What does a dyno run cost these days? Later J.
  5. Burt4x4
    6,854
    hahaha I hear ya
    Well this shop gets 100 bucks just to toss it up on the dyno fer 1hr and do 3 standard tests. The from there if you wana tune it's 100 bucks an hr. I was there about 3hrs and cost me 200 bucks. Not like they had a stop watch going..good shop with regular folks running it and having a good time doing so...wish that was my shop..thats fer damn sure!
    Good Times
    Burt
  6. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Dyno
    It's a nice way to find out actual numbers, well it's Saturday morning my play time. I want to get my timing chain in, it s#cks I have to crane my motor up just to do this work every time. Wish this crossmember wasn't in the way. I gotta find a better way!!!! Later J.
  7. Burt4x4
    6,854
    Well J,
    yer probly out side right now but I wanted to show you what I did to cure your issue of yanking the enigine just to take the tin off.
    I replaced my crossmember with a 73+ 4x4 truck/blazer SBC crossmember/engine brackets. I took an extra step and installed ORD's enine mounts. The black paint in the pic kinda blends all the steel togeather but if you find the bolt heads then the pieces are visable:D
    Now I can drop the pan with ease:D
  8. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Oil pan drop
    Do I understand you correctly, you don't have to hang the engine from the rafters to drop the oil pan???? If this is correct I'm off to the junkyard, thanks Burt. Later J.:bow:
  9. Burt4x4
    6,854
    Yup, thats the ticket.
    It swings forward under the front instead of our stock version that swings right under the oil pan.
    you will need to dril some holes. Two of the original holes line up with the 73+ crossmember to get you goin in the right spot.
    This is the artical i got the idea from.
    In this pic you can see the bolt head & nuts on the frame were the new crossmember and frame horns bolted to the top of the frame above the bumpstop bracket and then the two at the bottom dead center in the photo.
  10. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    crossmember
    Does the upper part of the motor mounts still bolt up as stock or do they have to be modified. I just bought new prothane mounts and I want to use them??? Thanks J.
  11. Burt4x4
    6,854
    I used new engine mounts so I am not sure but I would bet you need 73+ engine mounts.....
  12. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Motor Mounts
    Actually, I've been trying to find out if that new crossmember ORD makes would fit my first gen. sounds like from what your saying it could fit. I'll look the motor mounts up in prothanes cat. but I believe your right. I'll give someone a good deal on these mounts and buy new ones. Did you also have to get the top pcs. of the crossmember, the ones below the actual motor mounts??
    Thanks for the help Burt, you better go straitn up the house before the other half gets home, aleast get rid of all the beer cans haha Later J.:haha:
    Reread your original message and got the answer I was looking for on the upper pcs.
  13. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Nice jump after they got done with it - sounds like it was worth the money spent. Once you left could you feel a definite difference on the road?
  14. Burt4x4
    6,854
    Hey YJ
    Yes I could feel it.
    More in your seat feeling when I get on it:D
    Having the Air/Fuel right was the best thing for my engine.
    Nice having a strong BBC...lots O fun:D
  15. Ryan B.
    Jul 18, 2001
    5,693
    CA
    When i grow up i wanna be HellaG just like burt. :D
    Awsome numbers!
    Gotta love an injected rat! :bow:
