Good deal I hope. Have questions.
Discussion in 'The Garage' started by MTBLAZER89, Apr 16, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Ok here's the deal. I found a 82 K20 6.2 Diesel today.
    #1 Front end should be a Dana 44 correct?....I don't know what else came under these trucks. I know the rear is a 14bff.
    #2 Stamped on the ring gear is 41,10 I interrpret this as 4.10 gears correct??
    #3 If its a Dana 44 then it has the (good) internal hubs with a snap ring right..??
    #4 If I read in my searches correctly I can use my 10b calipers and lockouts right??
    Anyway I hope this is all correct the guy only wants $100 for front and rear. I just bought a 14bff last week for $75 so I'll have a 14bff for sale soon in Reno area. Thanks everyone/forums/images/graemlins/thumb.gif
    -Brian
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    If it's an 82 and nothing has been swapped out, it will be a 10 bolt.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    An 8 lug 10 bolt??
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Yep, I just put one in my truck from an '83. And yes you can use the calipers and lockouts.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Any more input?? Especially on the 41 and 10 stamped on the ring gear. The axle is missing hubs so I can't do the rotate the tire and count the revolutions of the driveshaft.
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    41 is # of ring geear teeth. 10 is # of pinion gear teeth. Divide the two, and your ratio is 4.10.
    -- Mike
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Cool thanks..Still don't understand why a 10 bolt is the front axle under a 3/4 ton with a diesel. /forums/images/graemlins/confused.gif Guess I was really just hoping it would be a Dana 44
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Why, they are almost exactly the same strength. They both use the 297x ujoint that tends to be the weak point in the front axle. I would trust a 10 bolt as much as a D44 anyday. I run an 8 lug 10 bolt myself. If the D44 was any stronger I would have put one in instead when I swapped the front axles.
  9. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    What he said /forums/images/graemlins/smile.gif
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Cool thanks everyone. I just got home from work on my way to go get the axles. $100 can't pass this up. /forums/images/graemlins/thumb.gif
    -Brian
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yep its a 10 bolt. LOL It is sitting in my gagrage getting ready to be rebuilt. If anybody wants the rear its an 8 lug 14bsf. NW Nevada let me know if you're close.
    -Brian
