good deal on a lift kit?
Discussion in 'The Garage' started by DUKE, Apr 14, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    found on ebay
    [link]http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1820731533&r=0&t=0[/link]
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    <a target="_blank" href=http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&amp;item=1820731533&amp;r=0&amp;t=0>http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&amp;item=1820731533&amp;r=0&amp;t=0</a>
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It seems to be a good deal. If you can get it for the $255, then it would be a good deal.
  4. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    That's the kit from rough country. I've heard that the spring rate is a bit high, but I run that kit on my suburban, and it seems to flex just fine. The only other thing you will need is brake lines, otherwise the kit is complete and even includes the arm. Instructions were clear, and everything fit well. Good luck!
