Good deal or not?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4blazer, Jul 21, 2001.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I found a 12 bolt with 3.73s and posi. The guy wants 400 bucks. Everything inside the pumpkin is fresh. I'm running a stock 12 bolt with 3.08s now. I will have to run with no front drive shaft for a little while til I can change the fronts to 3.73s. Should I jump on it, or is he smokin crack?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ask for the reciepts and if you can crack the cover open to inspect it. Also pull the drums off to inspect the brakes.
    $400 would be ok if everything IS good and new and rebuilt.
    BTW, even if you put this rear in the truck, you DON'T have to take the front driveshaft off. Just remember NOT to engage the t-case. [​IMG] Also, leave the lockouts unlocked, too.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    For a comparison, a Detroit True-Trac posi for a 10 bolt is roughly $330 new. Gears would run anywhere from $130-160, depending on brand. And installation of both could run you from $200-300. This is what I have found. So, if you were to try and upgrade your existing axle to this setup, it would run you about $600-800 (I assume a 12-bolt would be comparably priced). So, if it is good shape, it is a good deal.
    And, if you do this and have a 10-bolt up front, let me know. I am replacing my 3.73 front 10-bolt gears within the next month as I upgrade to 4.56s. Maybe we can make a deal.
    brian
    85 GMC Jimmy <a target="_blank" href=http://tx85gmcguy.alloffroad.com>tx85gmcguy.alloffroad.com</a>
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd go for it if you're going to run 33" tires or smaller, and they can prove it was properly rebuilt by a shop, and there is a warrenty.
    Otherwise go get a 14 bolt (either one). They usually come with low gears.
    Tim
  5. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    Thanks for the advice guys. I'm prob gonna go for it. I am runnin 33s and the guy I am buying it from runs the 4x4 shop that built this rear about 5mos ago, and hes givin me a limited waranty. Sounds fair to me.
  6. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Buy it if he can prove the new stuff.... just to have gears dropped in a pumpkin in my neck of the woods they want like $300 bucks! You got the whole set up for $400 which is a good deal here!
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
