Good Flex
Discussion in 'The Garage' started by 2High4U, Dec 14, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    What does everyone recommend for really good flex?
    Shocks\Springs etc..
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    shocks: as long as you can afford...
    springs: as soft/long as you can fit.
    j
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Thats pretty much the nuts & bolts of it
    Stock 52" springs up front and stock 56"s out back seem to be a popular combo because it's easier to accomplish. Some have gone with 56's up front and even 63's out back for added flex, but I can tell you that 52/56 is damn flexible enough for anything I'm going to be doing.
    Bear in mind that springs & shocks arent the only things you need to address. You need drivelines capable of handling the flex without binding up, you most certainly need crossover steering, and longer brake lines. Also, you will need fender "modification" and possibly modifed bump stops and limiting straps.
    Mike
  4. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    what brand shocks should i look at for the best possible performance im seeing that that would be the most expensive part for my suspension build.
    I dont want the typical rancho or pro comp brand
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    You shouldn't need fancy schmancy shocks like you see on the Mall cruiser rigs, just ones with enough travel to accomodate your suspension.
    I could probably use some longer-travel ones, but they're acting as my limiting straps now.. haha. They're $40 ProComp ES3000's.
    More importantly than brand, is you have to relocate the upper shock mount for shocks that big. The common consensus around here is either Ford shock towers or custom-fabbed brackets.
    I went with Ford super-duty shock towers:
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Mike knows what he's talking about. He's got the flexiest chevy that I have ever seen.
  7. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    Well i could do without the furd towers but relocating doesnt seem to be that bad of an idea and not hard for me do. I have some thick steel ill see what happens when i get all my chit straitened out
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    you are going to need the towers or custom mounts for shocks. the flex is to great for stock frame location of shock.
