Good gear ratio for 38's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Mar 13, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Good gear ratio for 38\'s?
    I plan on buying this 14FF from Wes here pretty quick and it has 4.11's in it already. I was just wondering what a good ratio would be to turn 38's. I stole a BIG parts catalog with lifts, shocks, t-cases, etc. from 4WPW and there is a gearing chart. With 4.11's, I'd be fine, but just curious what everyone else thinks.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Re: Good gear ratio for 38\'s?
    What transmission do you have???
    <A target="_blank" HREF=http://dblazer.coloradok5.com>http://dblazer.coloradok5.com</A>
  3. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    i have 4:88's in mine with 38's and it works real good on and off road. i have a 700r4 and 208 t-case.
    '85 Jimmy in Jax, Fl
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I had 4.56's on my old Jeep with 36's, and it was great. Even without an overdrive. I'd go with either 4.88's or 5.13's since you do have the overdrive. Later
    '73 K5
    Chevy good...Ford bad
  6. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    I have 5.13s for my 38" tires, and I would get lower gears if they made them for the 14FF. I would actually like 5.38s or 5.84s but couldn't find any when I bought gears. I have a Turbo 350, and the high rev on the highway doesn't bother me. I rev 3000 rpm at 60 mph and 3500 rpm at 70 mph (I think). Go as low as the pumpkin accomodates: 5.13. You'll be glad you did when you are trying to go down a dirt hill slowly or accelerate quickly. See my beasts at http://www.bigerik.coloradoK5.com . Good luck!
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Good job on the steal...that place deserves it.[​IMG]
    90K5
  8. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Like DBlazer said, what tranny do you have?
    If you're running an M465 you can get away with higher gears (what you have now).
    But you know how it goes the lower the better
    <A target="_blank" HREF=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </A>
  9. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    5.13's. When I get a 14ff I'm going 5.13's. If I can find a rear d60 then I'm going lower.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  10. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    I have 4.11's as well and plan on running the new 37x12.5x16 SSR's. I"m concerned my gearing will be too high for my 350/350/205 set-up, so I'm builing a big block. I'm hoping the tourqe will make up for the gearing.
    Coil sprung 71 blazer.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My project C14/D60 combo came with 4.56 so that is what I plan on running with the 39+ tires I will be installing as soon as I finish the mechanicals. If it were any lower, I would go with 5.13s but there is not enough difference (IMHO) to pay for the change from 4.56...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  12. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    I have a 700R4 tranny. I have heard the same thing about 4.56 and 5.13's..........there's not much difference. I'll have some time to think about the gears.
