Good people are too good sometimes :D
Discussion in 'The Lounge' started by Jagged, Mar 21, 2007.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    So, Pauly and I got the trailer all fixed up finally. Moved the #3 leaf from the left side to the right (where it was broken), and threw in a plate of metal about 1/4" thick. Now the right side of the trailer sits with plenty of wheel clearance. The shackle is still fully extended, but I think it will survive the trip.
    We went out for a rattle-run (where all your tools and parts you forgot about rattle off), and Pauly commented about the excessive vibration in the truck. It's always been like that, so I've just been used to it.
    Get back to the house, and took a look under the truck. I found a U-joint with a good chunk missing out of its cap (no visible bearings :eek:) and Pauly found my tranny mount needs replacing. I could probably use some new motor mounts to cover all my bases, but those are a PITA to change "just 'cause".
    So tomorrow... R&R tranny mount and U-joint.
    Maybe I'll finally get to go home sometime this week :D
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    motormounts are easy to change
    all you need is a floor jack and about 30 min.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Yup, and you probably want to change them at the same time as the tranny mount. I have read here that there could be issued with mixing old and new mounts as the motor and tranny won't flex the smae and could cau'se undue stress on the tranny bellhousing. I'd just bite the bullet, do the mounts and sleep easier.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have no meetings , testing , or anything else I didn't expect tonight . Marv hasn't called to come fetch the 14 bolt on the Sub yet , and I won't pick up any parts tonight .
    So we can get some picture time , and maybe eat before you leave . If you aren't done with the truck , I will help :thumb:
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    glad I had the opportunity to buy that rear diff, as i mentioned it when the sale of the Burb was done....:rolleyes:
  6. gofergurl
    gofergurl 1/2 ton status
    Jan 18, 2006
    1,565
    Blacksburg, VA
    Mitch took the truck to some drive-shaft place to get the U-joints replaced on the truck.
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I was told at the time of vehicle transfer, that the P.O. wanted to keep it, i mentioned when the Burb switched owners, that if P.O. ever decided to sell it, to let me know....but oh well:rolleyes:
  8. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    PAULY PAULY!!:bow:
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the big thing is no poly motor mounts and stock tranny mounts or vice versa
    but ya i would change them all at once
  10. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    I think I'm gonna wait until I get back to KS to do the mounts. The new U-joints fixed the "new" vibrations I've been having. The "old" vibration is still there, probably from the worn out mounts. I'll just deal with it until I get home.
