good place to get dual exhaust setup?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bryguy00b, Dec 27, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    would a place like a autozone or napa have a dual exhuast piping set or something for my k5? i want to get rid of the crap setup thats on there now and put a dual glass pack system on it that exists out behind the rear wheels on each side..
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Buy the Dynomax dual kit from Jegs and bolt it on. It'll work with glasspacks. That's what I used to have until I decided it wasn't loud enough and put straights on it.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how much does that go for? got a link?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Its a little over $100 plus mufflers. I've got one on each truck. Just go to www.jegs.com and type "Dynomax dual kit" in the box.
  5. methcat
    methcat Registered Member
    Dec 24, 2002
    17
    BLF, CA
    if youve got hookers on it now, summit sells a 2 1/4" system that i ran in my 75. it fit primo with any old turbos. /forums/images/graemlins/cool.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    will they bolt up to the stock manifolds?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes. They have a header kit and a manifold kit. Order the manifold kit.
  8. methcat
    Dec 24, 2002
    17
    BLF, CA
    they make both header and manifold kits for most applications. the catalog says $116 for most header types and 135 for most manifold types. i bought the header type cause i already had the hookers, so i know they make that one. pretty good quality too, it's all mandrel bent. no kinks! /forums/images/graemlins/thumb.gif
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool ill look into this guys....thanx! /forums/images/graemlins/thumb.gif
  10. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Will the manifold kit PN 289-89003 work on a Blazer with a 305?
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I run the Dynomax from jegs and I think its good bang for the buck. I'm about to get another one from them. /forums/images/graemlins/grin.gif
  12. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i got the dynomax header kit because i needed to completely replace my exhaust and figured it was a worthwhile upgrade...
    however i wasnt that pleased with my dynomax kit...its great because everything is prebent and looks nice....but i couldnt get those rears to line up together...
    my kit just doesnt fit perfect, its functional, but its a little bit off....i've heard others with this same complaint about the dynomax setup...but i've also heard more people say that it fit like a glove....
    the weirdest thing is that i used all dynomax, headers, pipe, mufflers, it sounds awesome, but i always have one tailpipe an inch or so higher than the other
  13. JakeInAZ
    JakeInAZ Registered Member
    Jan 11, 2003
    21
    Near Prescott AZ
    Ok, I spent a year dilly dallying with my exhaust until I found what worked (friend at a muffler shop comes in handy). I ended removing my Hooker headers because they are SOOOO notorious for warping and getting loose (if you try to "lock-tite" them they just warp eventually). With Hooker headers and 2 1/4 inch dual pipes (w/o cats) and Dynomax mufflers it sounded so-so and my blazer shifted into 3rd at about 68mph. I now run a ram-horns instead of headers, 3 inch mandral bent Edelbrock exhaust with cats(damn emissions) and flowmaster dual chamber mufflers. I have a TON more low end torgue and it doesn't shift to 3rd until aprox. 77-79 mph......and even better than sounding great and performing great it fits PERFECT and the entire set-up (minus gaskets of course) is gauranteed for LIFE. Check out Edelbrock.com....they'll send you a catalog (but it's actually cheaper to buy the parts from a parts store since Edelbrock has a tendancy to overcharge the general consumer).
  14. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    I know this may be a stupid question but, What are Ram Horns? just curious.
  15. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    If you want to upgrade to headers I know a guy who has a set for 50 bucks.
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ram horns are 72 and older exhaust manifolds they are upside down W-shaped, there are two versions, the common 2" exit ones and then the 63 64 Hi PErf 2.5" exit ones
    to get quick inexpensive 2.5" duals on a gm truck you get full length headers and a set of exhaust manifold gaskets for 55-up SBC and get four collector gaskets and use two on each collector and get how ever many feet worth of 2.5" or whatever diameter straight pipe and some turbo II or similar decent sounding inexpensive mufflers, and welder, you may have to torch some material from driver side of auto trans X-member, but oh well.. i torched alot of mine away up tot he bolts that hold the end bracket to the end of the main part of the member,three bolts stil hold it together plus the two larger frame bolts,
    its not like these members are rare, everyone has an extra auto trans X-member or two laying around
    this is what i did to the 81 scottsdale when i yanked the original 2 bbl 305 ESC setup in favor of 1975 350 4 bolt engine recently, been about a month and not any problems as far as exhaust /forums/images/graemlins/laugh.gif
    good luck
