Good place to mount tach wire?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Sep 1, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    I have one of those Sunpro 2-5/8" tachs and I've got everything connected except for the positve red wire which the instructions say can only be connected to a terminal that is energized when the key is in the "ON" position. I have one of those remote solenoids and was wondering if there is a terminal on there that would be ok to connect it to. Here's a picture of the solenoid, let me know which terminal to connect it to (A, B, C, or D) or if I need to connect it somewhere else: Remote Solenoid Thanks.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Honestly, I've always hooked it up at the fuce panel to a switchable fuce like (radio).
  3. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Good idea, I'll go and try that.
  4. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Ok I connected the red wire to the radio fuse, the white wire (light) to the dash panel light fuse, the ground wire to the bracket that the brake booster mounts to, and the green wire to the loose white wire coming out of the ignition coil. Whenever I put the key in the "ON" position without the truck running the tach goes to zero but when I turn on the dash lights, the needle goes backwards to 9k rpm. When the engine is running it shows about 1100 rpm but only goes to about 1500 rpm when you drive it. Any ideas on what could be wrong? A bad ground maybe?
  5. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Sounds like the wires are crossed maybe? Like power connected to the lights, or lights connected to the tach wire.... something like that. Does the light go on when you turn on the lights?
