good trick for getting old spring bushings out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Aug 30, 2001.
    going to replace the busings on a set of rear springs i have and i used an 1 1/8 socket and ratchet extention and just pounded them out with my BFH. worked slick, took 20 min. tops. of course the springs were out and on my garage floor so that helps too. make sure the socket and extention are ones you're not fond of cause they wont look the same after. just thought i'd share, it's rare when old sh*t comes out easy!
    <font color=blue>Striving for K5 world dominance</font color=blue>
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I usually set fire to them[​IMG]
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Ya I prefer the fire method but the neighbors dont,..
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Front 52"s?, What bushings are you going with?- still haven't been down that road yet. What is the I/D of the spring eyes? (1 1/8?)
    <font color=white>It's good to be out</font color=white>
    <font color=white>Out of my mind and out of control</font color=white>
    <font color=blue>Twiztid</font color=blue>
  4. hey twiztid,
    going to end up putting those springs on my work truck. the spring eyes are 1 1/2 " inside diameter. how's your rig coming along?
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Slow, but getting there[​IMG] It's back on the front burnners now!
    Good to see ya on the boards. Jason.
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Probably not good for the temper to subject the springs to the heat of fire.
    Socket method can be improved upon by drilling two or three 1/8" holes around the outside of the bushings.
    Lift It, Lock It, LIVE IT!!!
  7. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    <font color=green>most of us have tried to pound them out,and drill,,and file and and and,, doesn't alway's work. fire seem's to be the key to getting them out quickly with out breaking your hand's,leg's,shin's or any other part of your body that was close to the 20 lb sledge you were using. it doesn't actually need to be that hot, the bushing being made of rubber burn fairly easily and just fall apart, the spring doesn't actually see extreme heat,or shouldn't i should say. i usually give a few tap's with a hammer first to see if i can get them out easily,but it's just soooo much easier to use the " blue tip wrench ". takes about 5 minute's.</font color=green>
    <font color=purple>ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]</font color=green>
  8. RedDwarf
    May 9, 2001
    816
    Yeh, they can be a bitch.
    Just wondering what the long term effects could be on something tempered like spring steel.
    Got a set of '74 fronts that still have the original bushings laying in the pile, and I'm thinking about taking the bushings out. Ought to be a real laugh riot! We'll see if I resort to the "blue tipped wrench" or not :D
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats my favorite wrench! That and a welder.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  10. k5king
    Jul 23, 2000
    571
    <font color=green> can i borrow them ? [​IMG] my folk's moved way up north and would you believe my old man had the gaul to take his wrench and welder with him [​IMG] SHEESH ! now whut will i do ? i sure do miss them sometimes[​IMG]
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The flame from rubber or urethane won't exceed 450-500 degrees normally - It would take alot more than that to have an effect on spring temper, plus the bushing only needs to burn for a few seconds to be charred enough to remove easily. No worries as long as you don't get wild.
  12. k5king
    Jul 23, 2000
    571
    <font color=green>yeah,,as with any steel like that, if you get it hot it's going to lose some strength, but i think that some of the guy's on here ( look's around ) have had them hot enough to fry egg's on and still are using them on their truck. it's all kind of a guessing game, you want to burn them but not get the spring so hot that it's glowing red, that would not be good for it at all, but enough to get the bushing's out shouldn't really do any harm that you'd ever be able to see. i would rather use a 40 ton press to do it though.</font color=green>
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I just give them a little shot of WD40 or starting fluid and use a lighter - rubber loses integrity in nothing flat.
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
  15. k5king
    Jul 23, 2000
    571
    <font color=green>funny,,,that's whut i use to seat bead's when they don't go on like they should[​IMG]
  16. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Isn't fire wonderful?? The universal tool
  17. k5king
    Jul 23, 2000
    571
    <font color=green> LMAO !!! </font color=green>
  18. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    [​IMG] Thats what I was going to say. Torch those motha's
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  19. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    You definitely wouldn't want to heat the springs to a red-orange temperature as that is when you will start to anneal, or soften, spring steel. I think the temp is around 2000F, but is different for different steels, as you might imagine.
    That said, you can put a flame to the bushings long enough to totally annihilate the rubber long before the steel gets anywhere near that hot.
    So if you can get 'em out without the torch, cool. If not, don't be afraid of a little judiciously applied heat!
    John
