Good Vibrations...not!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TDAWG1, Jan 18, 2006.
  1. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    I have a serious vibation from the under side of my JIMMY. Whats the deal. My U joints apear to be fine. the ones on the rear shaft are new. Truck was driving fine then one day about 3 weeks ago. This vibration starts. I regreased all greasable areas That really helped in the front shaft which was dry. YIKES!
    I am waiting to fix some of the under problems because I am hoping to get my lift soon. Though the longer I wait to find this problem the more money I'll end up spending. Which also brings me to ask. does anyone know a good place to get some drive line work done in Grand Junction? I'll need it when I get my lift.Thanx 4 da help all and happy new year to ya.:bow: :haha: :doah: :wink1: :laugh: :whistle: :tongue1: :ears: :dunno: :k5: :1zhelp:
  2. 89-Blazer
    89-Blazer Registered Member
    Nov 14, 2005
    19
    Vancouver, WA
    Pinion bearings might be failing. Is the yoke still good and snug or does it wobble in the housing?
    Mike
  3. TDAWG1
    Jan 18, 2005
    2,836
    8
    Good thought thanx, but know I just got new bearings. I guess I'll keep looking.
  4. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    hey ill call you
  5. TheColonel
    TheColonel Registered Member
    Jan 22, 2006
    17
    SC
    Did you check to make sure all of the weights on the drive shaft are still intact? I had a similar problem and found out that my drive shaft had a weight that fell off causing vibrations..
  6. TDAWG1
    Jan 18, 2005
    2,836
    8
    That would be great!
  7. TDAWG1
    Jan 18, 2005
    2,836
    8
    i'll check the weights thanx
  8. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Check the bolts that hold the adapter between tranny and t'case to the rubber mount at the X-member. A while ago those bolts on my truck had elected to go their own way...
  9. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    i went over and im thinking part of it mabe a bad trany mount
  10. TDAWG1
    Jan 18, 2005
    2,836
    8
    Yup Thanx for coming over. that is a great place to start. Tanx 4 da help.
