good way to get a striped bolt out..
Discussion in 'The Garage' started by bryguy00b, Sep 3, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok im trying to take my parking brake release gears out..and they are held on by the two bolts that go through the firewall. well i got one of..but the other one is so demented the sockets wont grip it..and its caked with grease and crap from over the years..how can i get this bad boy of? and its in a tight spot..so i cant fit a cresent wrench or anything to big like that down there..
  2. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Dynamite, stuff works wonders /forums/images/icons/grin.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm ive never heard of that..wear do you get it..
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    How bout some vice-grips..the needle nose.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea ive tryed all that, its hard to get in there with them to begin with and it just wont grip it hard enough..
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    dynomite=explosion like in Blow it up.. I think it was a joke..
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    AHHA..wow do i feel like a dumb as* LOL.. /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/tongue.gif
  8. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Do you have a welder? If so weld another bolt to the head of that one and use a socket to unscrew them as a unit. If you dont have a welder find a shop or friend that does have one.
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thats a good idea..but it seems almost a little extreme..(i dont have a welder either)damn i cant beileve how the simplest things can turn into such hassles sometimes!
  10. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    First of all, get all the crap off of it. Use a screwdriver or something to scrape it off. You can't expect a socket to grip something that is covered in crap. If after you clean it, you still can't get it, here's what to do. Find a socket that is just a little too small for the bolt head and drive it on there with a hammer. If that doesn't work, you can always put a little of that liquidy JB weld in the socket first, drive in on with a hammer, then let it harder. You'll probably ruin your socket, but your bolt should come out.
  11. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    is it too small a space to get in a sawzall?or maybe a small hacksaw?the weld a nut on the end trick i have never heard of but sounds like a good idea.also like others said clean it up so you can see what you have to work with.then maybe try a metric socket to fit it a little tighter.the sizes are off just a little bit off in size from standard so maybe you can get a metric one to fit tighter on it.
  12. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    <font color="blue"> </font color>
    What about using a small 6 or 8 in pipe wrench?
    Or Craftsman has that "strap-wrench" thing that might work.
