Good way to measure for driveshaft?
Discussion in 'The Garage' started by Pow06er, Nov 16, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    Can this method be used?
    Ok unbolt d-shaft, slide it all the way into the tcase, pull it out about an inch, then measure the distance from the pinion where the ujoint rests to the end caps of the ujoint on the driveshaft.
    That should work correct? and when i install i should have enuff room to slide it in an inch to bolt up driveshaft to pinion?
    Is an inch exposed not enough or should i have about inch and quarter left exposed?
    I dont want it too far in the tcase to where it will bottom out against tcase under extreme cases.
    Anything else i shoudl look out for would be helpful
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    well the place i called said that the amount i want it extended is my call
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
