Goodwrench 350 tbi
Discussion in 'The Garage' started by keevy, May 10, 2005.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    Is a new Goodwrench 350 TBI engine a good engine to replace mine old engine? Other options?
    Thanks allot
  2. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    YES!
    I had one and I was more than pleased with the performance, relability, and ease of installation
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yep, I did the same thing. I havent have the slightest problem with it yet. I was thinking about an upgrade to a higher HP model at the time, but I chosed the factory reman.
    If I were to do it again, I probably would have chosen the higher HP from an aftermarket, or GM performance line, but I was not planning on offrading the Blazer then. It depends on your needs and wants.
    But all around value, warranty, and avaiability, I would say yes.
  4. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Stock engines are ok but if you want a little more HP check out cfm-tech, the make a kit so you can run tbi on a GM 330hp crate engine. A little more expensive but not a bad deal, thats what I am going to do when my stock engine gives up. Plus I am running there throttle body and some other stuff and love it.
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Well mine wasn't a TBI engine but still a GM Goodwrench. 290 hp with headers and 650 carb plus and Edelbrock Intake. Wasn't bad in stock form with the carb. Once I fuel Injected it, WOW. I found great turn key deal on nmine at Pace Performance on the web.
  6. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    What's your budget?
