got 14 bolt in now have disks on and have a prob??
Discussion in 'The Garage' started by chulisohombre, Apr 2, 2003.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    is there something in the propor valve that holds pressure in the rear brakes?i thought i heard something about it but was hopeing mine was worn out or something.my rear brakes have pressure on them now and dont turn.dont want to ruin my new toys before i have a chance to use them.anybody help?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You need a prop. valve for disc brakes front and rear.
    Dan
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    You can gut the stock proportioning valve to get rid of the reidual valve. If the write up isn't in the technical forum, it is in the bloody knuckle. You have to be a member to access it, but this question is exactly why i joined. I had no time to research it, and as broke as i am, i forked out the 25 for the information. Well worth the money!
  4. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    That write-up is part of Grim's write-up on our 10/12 Bolt disc brake article. It's on the front page /forums/images/graemlins/thumb.gif
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I plan on just buying a replacement from Inline Tube. Mine is pretty shot anyway and I did the rear disk conversion. I'm going to replace all the brake lines and fuel lines with stainless steel and will use their proportioning valve. You can see it here: http://www.inlinetube.com/Prop%20Valves/VCT104.htm
  6. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    It seems that I've heard that you can run the front discs straight (no valve) and run the rear through a valve--the stock one or an adjustable one though, I'm not sure. Anybody?
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Thats how i did mine. straight to the fronts, and adjustable valve to the rear. There is no failsafe though.
    Using a regular valve would be better, but I had the valve.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I see lots of confusion and dis/misinformation here.
    There are three valves commonly in a brake system.
    Proportioning valve - Regulates the pressure to the REAR brakes only. (Some special applications are different, but not on street driven vehicles.) OE are usually fixed proportioning rate, aftermarket have an adjustable proportioning rate. Must be installed downstream of the valve mentioned next.
    Shuttle Valve - turns on the brake warning light when one half of the system fails and theoretically blocks off the leaking/failed half.
    Residual Pressure Valve (RPV) - maintains a little bit of pressure in the line when your foot is not on the brake pedal. Most common on drum brake apps, used to keep the springs from completely retracting the shoes and causing a long pedal travel b4 the brakes function. In some cases they are needed in disc systems where the m/c is below the calipers. Drum versions typically keep 10 psi in the line. Disc versions only keep 2 psi in the line.
    Rear disc conversions can sometimes suffer from the rear RPV still being functional. It will cause the rear pads to drag. The RPV(s) are usually located in the m/c under the little brass cone that the outlet lines seal on. The easiest way to remove them is to run a small tap down the hole. When the tap bottoms out, keep screwing. This will pull the cone out so that you can remove the valve core. Re-install the cone and you're ready to try again.
    Any old flex hose in the system can also cause a dragging condition. They develop 'flappers' in them sometimes, and these flaps act like check valves holding pressure in the line.
