got a code 12
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Oct 25, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    OK so put on the TBI system, but now I’m having a problem. I drove the truck around yesterday and it started bucking upon acceleration. The truck idles fine but when I take off and hit the gas it just sputters. The truck felt like it had no power. When I pulled the trouble codes by jumping the aldl terminal I found a code of 12. Code 12 showed to be something dealing with the distributor spark to the computer. I checked all the wires dealing with the distributor the only thing I have not checked is the timing due to my timing light being broken. I added the VSS from the computer to the existing wire for the cruise control. I’m beginning to think the cruise control wire is not the right one. Does the VSS have anything to do with this?
    Thanks,
    Charles
  2. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    A code 12 just means that you accessed the computer. Check you fuel filter. The does the same thing when it is clogged. Runs fine at idle then runs sluggish when you give it gas. Hope this helps.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Don't think so.........the VSS pulse generator has two wires (forget the colors) that have corresponding hookups in the wiring harness...............you have to have an actual VSS generator feeding the computer the info, the cruise control will not work. www.jagsthatrun.com is but one source of VSS pulse generators. /forums/images/graemlins/laugh.gif
  4. Stylzz
    Stylzz Registered Member
    Sep 9, 2002
    95
    Mystic, CT
    It should show a code 12 first then give you the trouble code and then show a code 12 again. Its just to let you know the computer is working.
  5. BurbinOR
    5,829
    Oregon
    By the way, I'd recommend you get a scanner or something like WinALDL to read the computer info - very valuable info even if it is not throwing codes. Helps out on drivability problems, etc. I have an AutoXray ( www.autoxray.com ), available at Shucks/Kragen/Checker stores or others.
    Jumping the terminals on the ALDL is fine for code reading only, the scanner can tell you much more. /forums/images/graemlins/thumb.gif
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Is the computer setup for computer controlled distributor?
    Or a regular mechanical advance weight distributor?
  7. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    As the others have stated, a code 12 is a handshake code. It also signals no distributor reference pulses, which stands to reason if the engine is off.
    I would check two things:
    1) Ensure the distributor is the computer controlled variety, not vacuum advance.
    2) Check the fuel system, specifically the pressure and regulator. I put an adjustable regulator on my truck with great success.
    Good luck and let us know what you find...
    /forums/images/graemlins/burb.gif
