Got A D60 now have some ?????
Discussion in 'The Garage' started by BLZN4FN, Jan 9, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Its been 3 years in the making but got the 60 :cool1:
    Questions are
    How do you tell if the brake calipers are good?
    I took them off and looked at them looked ok. So I put them in a vise
    and compressed the piston went good then put air to the caliper and the
    piston moved reinstalled in the vise compressed felt smooth so what do you think?
    2) Will my SS brake lines from my 3/4 10bolt fit on the D60 calipers?
    3) Drag link from the box to the arm is it the same?
    Reason on this is the drag link I just replaced all with new ends
    would like to use if possible.
    4) Is there any other thing I sould look for when going through the D60
    Bo
  2. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    One other Q will the U-joint on the ft drive shaft fit the yoke on a D60?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    draglink is the same and your brake lines will bolt up. I replace calipers when they are more flakes of rust than actual metal. Don't know the real way to tell. I'd say replace them, new ones will be better than driving around with ones you don't know about.
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Make sure the bleeder valves work, i checked the calipers that were on my 60 they seemed fine so i spent alot of time grinding them down for 15" rims just to find out that I couldnt bleed them because the valves were in there for good, so now i have new calipers and 16.5" hummer rims
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I thought the 60 has the same yoke as a 10, but I could be wrong.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah should both be 1310 joints.
  7. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    If it's too much trouble, drop it off at my house.:grin:
