Got a fireball out the carb...
Discussion in 'The Garage' started by 8_YOUR_H2, Feb 18, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    So now I have my POS ready to start and I got the old fireball out the carb routine. Does this usually mean the distributor is 180* out, too far advanced or retarded?
  2. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    That or your plug wires are in reverse or wrong order.
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    The rotor should be pointed at about 7:00 at TDC of compression stroke if you are looking at the distributor from your fender. The firing order is 18436572.
  4. muddy81ca
    muddy81ca Registered Member
    Apr 19, 2005
    8
    CAlI
    check timing > and plugs X4
