got a front u joint question
Discussion in 'The Garage' started by ShitownK5er, Oct 10, 2006.
  1. ShitownK5er
    ShitownK5er 1/2 ton status
    Nov 7, 2000
    121
    Shillington Pa
    Im ready to install my front drive shaft. I have a 1 ton shaft but only a 10 bolt front does anybody know of a "trick" u joint that will work. I know the napa #447 is for the 14 bolt to the stock driveshaft i need the reversal of that ujoint?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you dont need the reversal, you just put the 1350 part in the 1350 part and the s44 part in the s44 part. i think the 10b came stock with s44s up front so you would need the same exact u-joint if you have a 1350 shaft
  3. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    all stock frt shafts use same joints.
    but true 1 ton shaft is longer.
  4. ShitownK5er
    Nov 7, 2000
    121
    Shillington Pa
    i did try that but the way it mounts with the "c clips" will be reversed.
