got a problem
Discussion in 'The Garage' started by bigbadchev84, Mar 24, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok im trying to sell a 78 ford with the 400m. i was driving it the other day for the first time in 5 months and got on it kinda hard after it was kinda studdering, i thought it was bad gas and it was running a little rich, so i was trying to clean it out, well anyways the thing idles reall rough now and when you rev it up it sounds like the rocker arms are loose, on a ford you cant adjust them just tighten them down to 23lbs. i was pulling all the plug wires one at a time while running and 3 cylinders on the pass side didnt really make a difference when i pulled them, si i think they are dead. what does this sound like and where should i go from here? i need to get this thing fixed right so i can sell it
  2. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    If it was running to rich it may have fowled a couple of plugs. Thats where i would start
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    come on guys i need to get this fixed.......please point me in the right direction
  4. Storm Trooper
    Nov 24, 2000
    4,640
    Check the compression on the three cylinders that didn't make a difference.
    You might have a stuck valve(s) from it sitting.
    Oh, and check for spark. Thoughs Dist. caps like to build up crap on the contacts.
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    your hydro lifters might not be pumping up, try changing the oil
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The pull the plug wire trick isn't a good "trick" because on a V/8 engine there are usually 2 or 3 cylinders that will not change because of the firing order. The first thing is to drain and flush all the old fuel out, fuel becomes bad after 5 or 6 months even though you may not believe so. Second i would change the oil and all the spark plugs, bet it runs good after the new gas and spark plugs.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Good gas ,tune up, oil change, (not necessarily in that order.)
  8. goldwing2000
    goldwing2000 Guest
    It's a Ford... you probably jumped the timing chain when you hammered on it.
