Got A Question about my rear window?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Krase, May 26, 2002.
  1. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    I just got my 88 k5, lifted it 4" and threw some 33's on it for now. I am in the process of working out the few minor problems that are known to me, such as this one. My rear window rolls up and down just fine with no problems, except when in the fully down position there is about a half a inch of window still sticking up out of the gate, is this right or should i take the gate apart to find out whats up, or what is your guys opinions? Thanks for the Help.
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    my 88 does the exact same thing only some days its a little bit farther down than others...i just deal with it, didnt know if there was a way to fix it or not...
    Later
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    pull the panel off and look inside. might just be a bunch of dirt inside or the window might be in wrong.
    grant
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Take the panel off and look inside and you will find a window stop. You may adjust the stop so that the window will go down farther.
  5. Krase
    May 19, 2002
    90
    Ok, i took the panel off, and remove the rubber stopper and rerouted the cables, but still have like a quarter of an inch left, i agree this is not much, but when in a couple of weeks i will be hauling two kayak's around, i dont want to take the chance of cracking the glass, the metal bar that goes into the stop channel operates fine but for some reason it wont go down any further? Is this a motor problem (even though it goes up and down with out a hitch and fairly quickly) or am i missing something.
  6. dyeager535
    26,975
    Is that stock that they stick out somewhat?
    I never tried 'adjusting' my '83 or 87 tailgates to get rid of the partial glass problem, but I just figured it was a stock deal for some reason. It would obviously be kinda dumb for that to be stock though...
    If you figure it out, let me know, although I gotta get back into mine to see why the key switch isn't working again. (last "fix" worked all of 5 minutes after complete re-assembly lol)
  7. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    I think it is designed that way because if it goes down any farther you run the risk of the window going below the rubber weatherstripping, then the window would get wedged in the down position. I wouldn't worry too much about it, the window is pretty strong so you shouldn't chip or crack it.
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    my window is chipped already and want to prevent future chips, so if anyone figures out a fix for the problem, keep me in mind.
  9. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Yeah i have the same deal going on. Just a week ago i hauled two motocycles in the back and rolled em right over that little bit that sticks out. Alsoi had the cover off tailgate and the tires kinda rested on the glass. 300 miles and no breaking. I was worried but its okay.
  10. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Lube the cable
  11. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I got the same deal. I took the glass out and installed new channels R & L (includes new felt) cleaned & lubed every moving part and even took out the the rubber bumpers in the bottom of the gate. Still have about 1/4 in of glass showing. My buddy suggested having a glass shop cut the top of the glass off.
    Jim
  12. abusedtrucks
    abusedtrucks Registered Member
    May 11, 2002
    76
    Upsala , MN
    My window was shot at and is shattered, yet it still rolls up and down fine. A few little chips shouldn't hurt it too bad.
  13. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    The glass in my 76 goes all the way down. Nothing showing. Doesn't catch on the weatherstripping (which is new). It's a manual.
  14. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    The window should go all the way down in the gate. The run channels on each side are probably full of dirt or some thing or maybe just a weak motor. As for having the top of the glass cut of you can't unless you have the laminated backglass wich is kinda rare no only that then when you rolled it up there would'nt be enough to reach the top
