Got a question abuot 57" springs,,,,,
Discussion in 'The Garage' started by Silver84k5, Sep 11, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Got a question abuot 57\" springs,,,,,
    im definatley going to do this mod this winter, I just read Rene's article (good article i will be following it on my swap) But im gonna need more then 4.5 inch lift i need 7-8, What do you suggest i do? the only block i will run is the zero rate and the body lift ill use is the 1 inch, do they make a 57" long 2 inch lift spring that will work on my truck? TIA
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: Got a question abuot 57\" springs,,,,,
    Aftermarket they do. Rear 2" lift springs from Rough Country.
    Rough Country
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i read Rene's article about it and he said that it was out of a 2 wheel drive? are the rear springs same for 4wd and 2wd?
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I doubt they are the same...but they may be similar. I'd have to check out a 4WD F-150 and do a heads up comparison.
    Rene
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    so could i use some lift springs from a f150 truck, ie not the stock ones but soem , say 2 inch lift springs... as long as there 57 inch by 2.5 inch... /forums/images/icons/smile.gif
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I don't see why not...the 2.5" width is probably the more important dimension.
    How well an aftermarket spring flex's is the unknown though.
    Rene
