got a question bout 700rs?
Discussion in 'The Garage' started by oatsk5, Dec 5, 2002.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    Im sorry if this has been asked but what is the ratio in od in the 700r trying to figure the right gears for moderate highy driving with 4.56or 4.88 gears? Any info would be great /forums/images/graemlins/k5.gif
  2. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    700's have a .70 overdrive ratio. the best gear ratio is going to depend on your tire size. I have 38.5's and am going with 4.88's Remember everybody, your worst enemy with going to bigger tires is the weight increase. 1 pound of rotating weight is equivilant to 7 pounds of vehicle weight. you need to regear to regain all that lost power
  3. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    Thanx for the info i think im going with 35s or 37s mabe in between dunno Thanx though. /forums/images/graemlins/k5.gif
  4. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    Ok next anoying sp? questions are what the low gear ratio in the 700r and the low gear in the 208t-case? /forums/images/graemlins/k5.gif
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
  6. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    duh i new that big brian fart /forums/images/graemlins/blush.gif Thanx /forums/images/graemlins/k5.gif
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    35's you'd want 4.56...my 4.10's barely cut it, I'd like more gearing. 37's go 4.88
  8. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    Im running 4.88s with 35s and 700r4. with overdrive i can still haul a$$ on the free way. 4.56 would be good but if you ever plan on going bigger might as well do the 4.88s. its still very drivable on the SoCal autobahn with the slight increase in RPM.
  9. Joe T
    Joe T Registered Member
    Apr 28, 2002
    23
    El Cajon Calif.
    I've got 35's & 4.56
    If I had a chance to do it over, I'd go 4.88
  10. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Mine has 4.56 with 35's I don't mind it at all. The OD helps a lot.
    Eric
