Got a S15 Jimmy
Discussion in '1983-2005 S-Series models' started by Muddytazz, Nov 19, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I picked up a 90 S15 Jimmy 4wd the other day for $1000 for the wife.
    Digital dash, 4.3L, 700r4, don't know the tcase yet, very clean inside, outside is faded rattle can white paint :haha: anyways, it has a couple of issues that I'm trying to fix right away.
    1 - on the digital dash, just the speedo area (speedo, blinkers) fades on/off when it wants too. If I slap the side or top of the dash, it will come back on, sometimes for a few sec, sometimes for hours. Like I said, goes on/off whenever it wants too.
    2 - fuel gauge issue. Don't know if its the gauge, ground, sender or what. But it reads wherever it wants too also. Sometimes it will read full ALL the time, sometimes it will slowly go down(don't know if its actually going down at the same rate as the tank tho).
    Anyone ever deal with this?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    There's a ground near your left foot when you are in the driver seat. That's probably loose...it's up at the bottom of the dash, 10mm head for the bolt/nut.
    The other thing I'd check the float to make sure it's got proper resistance. Sometimes the baffles in the tank come loose and mess with the float....
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I've seen the speedo issue on a friends '89, haven't tried slapping it around at all. Maybe we should check for that nut.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I found some info over at an S10 forum. Apparently these digital dashed S10/S15 vehicles were/are prone to have dash issues like this and the problem is INSIDE the dash on the printed circuit board. There is a couple guys on ebay that sells repaired dash boards on exchange for your old one AND they come with a 5 yr warranty ONLY if you send him back your old one AFTER you install the new one in a pre-paid package.
