Got a sb head out of your truck? A question for you
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jed, Jun 11, 2002.
  1. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    If anyone has access to a chevy small-block driver's-side head out of the truck or stripped of the power steering pump bracket I really need your help!
    Q: How deep is the threaded hole in the head casting for the power steering pump bracket pivot bolt? (not the bracket part near the exhaust manifold but the one by the water pump).
    On my truck this is the hole closest to the head gasket surface and towards the passenger side, quite close to the driver's side water pump bolt. It's a 3/8 NC16 hole.
    The reason I ask is that I'm removing a broken bolt and remnants of an EZout from this hole with a dremel grinding bit and it would really help to know how deep to go.
    Thanks!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1/2" is deep enough. It's deeper than that, but you only need as much depth as the diameter of the bolt you're going to use usually. Since it's a 3/8" bolt, 1/2" of depth is more than enough.
  3. Jed
    Nov 3, 2001
    60
    Alberta, Canada
    Sounds like a good rule of thumb. I'll give that a go. Thanks.
