Got a shimmy... :(
Discussion in 'The Garage' started by MountainMan, Dec 16, 2004.
  1. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    Yesterday the rig (86' 135K miles) started having a little shimmy during normal acceleration, if i accelerate hard or coast i dont feel it. Fluids are ok, I do burn oil a bit so I am wondering if i have lost a spark plug if it would feel like this? I will check those when I get off work today...
    Any thoughts of other things to check would be helpful, thanks
    P.S. how bad is it to over fill your transmission fluid? if you are a qtr inch higher than the FULL WHEN HOT on your dipstick when you are cold. How bad is that? ( I will drain it but I'm just wondering)
    THANKS FELLOW K5ers!!!
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Check your drive shaft's U- joints for the shimmy.I was told it's worse to have too much fluid than it is to have not enough.
  3. K5HIGH
    K5HIGH 1/2 ton status
    Dec 8, 2004
    102
    harrison twp. mi.
    COULD POSSIBLY BE IN THE TRANS. DOES IT KIND OF SHUDDER WHEN YOU LIGHTLY ACCELERATE? HAVE YOU CHANGED THE FLUID AND FILTER IN THE TRANS. POSS. UJOINT, HOW MUCH OF LIFT, ANGLE ON REAR DRIVESHAFT? YOLK ALL THE WAY IN THE TRNS CASE?
