got a winch (pics)
Discussion in 'The Garage' started by steve_kibbe, Aug 19, 2005.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Ended up getting this when I picked up another np 205.
    I think I'll use it in the shop and for a trailer/spare. I might
    make a plate for it to bolt to so I can put it in a reciever hitch.
    Let me know what ya think :D
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    That would be pretty sweet on the front of a trailer. Nice score :D
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    that would be real hard to use pulling your truck up the trail :p:
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I think it could be used with a pto, the other end of the shaft that goes through the worm gear is long enough and has a hole drilled in it for a pin to go through.
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    good score!
    You could use that style of winch on a hoist or crane also--its a "worm gear" style,that is self locking--if you lift a heavy load and let go of the handle,it wont spin wildly and let the load crash down,instead,it will hold the load wherever you stop cranking it--and you'll have to crank it in the opposite direction to lower the load...
    Same thing if you get a car halfway on the trailer,and have to stop to move something--you can just let go of the handle and the car stays put--no running to stick chock blocks under the tires...only bummer is it most likely won't "free spool",and you'll have to crank it 10,000 turns to get the cable out far enough to reach the car--then 10,000 more turns to yank it on the trailer.. :doah: --hope you have stong arms,because if you dont--you WILL! :haha: :haha: :crazy: maybe you can adapt a reversible motor to it..
