Got hydro assist on.... Broke driveline
Discussion in 'The Garage' started by MNorby, Aug 26, 2005.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    Well, got my hydro installed tonight. Work ok but need to turn pump up more or put smaller pulley on pump but can still turn tires against hard object and slide truck over :laugh:. Well, Though I oughta truck a wall climb since I haven't really put the narrowed bed to good use yet after doing it. Have some storage containers out back behind the shop. Well, my PTO front drivline gave loose where I jointed the stock tube from the CV to the tube of the PTO for the sqaure flange. Next time I will sleeve and plug weld the joint (was kinda wondering if would hold up anyways but this was a good test :rolleyes:) Well, the pics speak for themselves....
    I pointed out the highest tread mark in the one pic. Thought about getting out to take a pic there but though I could go higher and BOOOOM and came to a crashing fall. Ahhhh, good times. Trial and error.
    Moral of the story.... Hydro is awesome.
  2. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Seems ya "can't win for losing" sometimes! Goodwork on the assist.
  3. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    did you tap your stock box (in the steel) or use the alum caps with the fittings? I amm rounding up parts for this and your real world input would be appreciated. alot of what i have read seems to be frome people who have ideas but haven't done it yet themselves. also is your pump stock or did it actually need the upgrades too? Thanks
    BTW cool doors and taper :waytogo:
  4. MNorby
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I did mine in the housing as shown on www.k5crawler.com. It was cake, just keep cleaning the metal filings as they appear when drilling and tapping. I had to grind the end off the pipe side of the 1/4" pipe to 1/4 (-4) JIC fitting so it wouldn't hit the internals in the box but no prob. I can take pics of the box if you'd like.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    please do, pics would be great. i understand what you said, but pics point out the subtle details
  6. MNorby
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I'll get some monday when I go to the shop.
  7. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
  8. MNorby
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    Sorry for the delay but here are pics of the box...
  9. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Are those lines custom made or off the shelf? I have everything to do it including the ram and the tabs mounted, just need lines.
  10. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    what is the size of the hoses you are running. thanks for the pictures
  11. MNorby
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I made them with hydro hose we have around the shop and aeroquip fittings. They are 1/4"
