got me puzzled...
Discussion in 'The Garage' started by Mad-Dog, Aug 1, 2005.
  1. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    My neighbors truck quit running so went over to fix it, when he cranks the engine fuel sprays out the front float vent :crazy: on a single-line, dual-feed holley 600......so i checked the float level and it's ok, rebuilt the carb replacing float valves at both ends (still shooting gas out front bowl vent) :confused: , replaced front float bowl and double checking float level (still spraying gas out vent) :mad:
    I have checked everything....so i start thinking that maybe the fuel pump bypass has failed and too much fuel pressure is present at carb and overcoming the float valve so we replace the fuel pump (still spraying gas out front float vent) :haha:
    I'm at the end of my rope with this thing.......i have thought of every possible scenario theat could cause but i am still missing something :doah: ....got any ideas?
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Are you sure the floats themselves are still good? Even if they are set correctly, if they are sinking that would cause what you're experiencing.
  3. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    i replaced the float.....
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what about the needle and seat?
  5. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    mechanical pump??
    It could be excessive fuel pressure,if your sure the float is set correctly and is not sinking...only way to tell is to splice a "T" fitting into the fuel line and add a test gauge...one of those fuel pump/vacuum gauge testers cost about 10-15 bucks at parts stores..
    Only reason a mechanical pump would make too much pressure if if the diaphram gets old and hard,or if the pump has too much "stroke" on the pushrod...you can add gaskets between the block and pump if thats the case,but I've never had to do that on a chevy motor!--usually the pump itself is to blame if the pressure is too high--is it an old,original looking AC Delco fuel pump??... :confused: :crazy:
  6. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    yes i replaced the needle n seat (float valve)....
  7. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Replaced the original pump with another factory pump, no change....
    Replaced the float and rechecked float level, no change.....
    Replaced the float bowl, float, needle n seat and rechecked float level again..............No frikkin change :mad:
    I'm missing something here, well I'm on my to California then back to Florida so i got plenty of time to ponder while i take a break here in Albuquerque,NM :bow:
  8. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Try replacing the power valve. Holleys are famous for blowing them.
  9. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I as I understand it, a blown power valve would only cause the idle mixture to be too rich. I don't think it would cause this type of back pressure like problem.
    Mad-Dog, what about a restiction/blockage in the crossover tube?
  10. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Agreed, i have already ruled out a blown power-valve..........
    The transfer tube was checked when i pulled the carb apart,
    i have been thru this motor top to bottom, valve and ignition timing,
    pulled the covers and inspected the valvetrain.
    I appreciate all the help guys, i wanted to kick this around a bit while
    I'm out here on the road so maybe I'll have some fresh thoughts when i get back to the house in a week and a half......... :bow:
  11. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    Does it have a catalytic converter? The only thing I could see is either it has too much fuel pressure, or, walk through this with me. Could it have back pressure in the intake. If it did could it bleed enough through to the mixture screws. How much blowing fuel are you talking about? Do you have acess to any clear sight plugs? Maybe you could see if the bowls are being taken over by fuel. Did it just quit running all at once? have you put a vacuum gauge on to see if there is poitive or negative pressure in the manifold? Got me thinking too.
