Got my 14 bolt ff and 36" swampers
Discussion in 'The Garage' started by SF87K5, Nov 27, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Got my 14 bolt ff and 36\" swampers
    Put my 14 B FF in my 85 K5 last saturday. God it looks sweet, I also put my 36x14.50x15 TSL radials back on. I cant wait to get my gears and locker and go play. /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Got my 14 bolt ff and 36\" swampers
    4" of lift? That looks great . /forums/images/graemlins/thumb.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    danny, kick ass!!!!
  4. SF87K5
    Oct 27, 2002
    1,105
    That is finder trim and a 1" ORD body lift. /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Wow, stock springs? I'm definitely gonna be fine at 6" of lift and hacked then with my 38.5s. /forums/images/graemlins/smile.gif
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    She's looking good Danny, love that back window. /forums/images/graemlins/thumb.gif
  7. SF87K5
    Oct 27, 2002
    1,105
    84_chevy_k10, you you will. I am going to do a 6" front springs and a echobit flip with a 1" zero rate for the back. Some time in the future I will be running 42" TSL's.
    Yunit thanks. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    My manual regulator for my window broke along with the handle mechanism. I found a regulator in PA, now I just need to get the handle parts and I will be back in buisness.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I've got now, 6" springs and the Echobit flip in the rear. With the D60 I'll be sitting an inch higher or so. I'm ditching my body lift so that'll put at 6" or so of lift and I'm gonna run my 38.5s like that.
    I think I am going to try to take the lip off the cab floor like steve fox did so I don't have to worry about rubbing. I definitely don't care about hacking metal away I just want to keep my inner fenders.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    score! looking good, i like it /forums/images/graemlins/laugh.gif
    i bet truck is now alot better with bigger and deeper geared axles than it originally was /forums/images/graemlins/laugh.gif
  10. SF87K5
    Oct 27, 2002
    1,105
    Tim here is what the tire to finder clearance looks like with stock springs and 1" body lift and poly body mounts. I am going with the TC springs from ORD.
    The 14 B is 3.73 and the front is 3.08. I cant wait to get my 4.56's put in so I can use my swampers again. When I had my buddies 35" BFG MT's on I never rubbed of had the springs maxed out when we where up in Uwharrie. /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Thanks. I think I'm hacked even further than you in front so mine will probably be fine.
  12. SF87K5
    Oct 27, 2002
    1,105
    Tim, yeah I need to do something about the front. I am thinking about cutting it at a angle so it will clear the tire. But remember mine has no lift, so with a lift it whould be good.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wasn't saying you have an insufficient hack job. Looks great actually. I just took a few more inches off the rear of the front fender.
  14. SF87K5
    Oct 27, 2002
    1,105
    Thanks for the comploment. /forums/images/graemlins/thumb.gif
    Also thanks to conoverbandit for helping me with my rear end swap. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I like it, that is the way I wanted my 'Burb to look /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  16. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thats fricken awesome..36's with 1" lift..thats awesome!! ive thought about just putting some zero rates on all 4 corners of my truck along with the 2" add a leafs so ill have around 3 inches of suspension..and then like a 2 or 3" body..give me around 5-6" of lift..and would be a really cheap way to go, and throw some 3/4 tons under it..untill im lucky enough to land a 60..and stuff the biggest tires i can on it, with some good fender trimming, enough to wear i can max them out pretty good, of course i do maniy all mudding so flex isnt usually to much of a worry. but i think a setup like that or something would do pretty well for me!
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's exactly what my friend did...he took my 1st suspension lift from me. I had put an add a leaf in the front and a 3" block in the rear with stock everything. A few months later I went to a 4", a year later a 6", then the 3" body....
    My buddy took my old add-a-leaf and 3" rear block and threw them on his rig with a 3" body and put some 35s on his rig and its /forums/images/graemlins/thumb.gif for hardly no cashola expended.
  18. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Looks Awesome Danny!!
    I bet you can't wait to get that motor built and the rest of the axle stuff done. It should be quite the rig when it is finished!! /forums/images/graemlins/thumb.gif
  19. SF87K5
    Oct 27, 2002
    1,105
    Ben your telling me. I cant wait to get my engine and my axles built. /forums/images/graemlins/thumb.gif
    Kelly thanks alot. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
