Got my crate motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 5, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Just got my deluxe 350 330hp motor thingy. A couple of you probably remember me asking about switching my TBI to carb. Well, now since I've got the carb motor, what parts do I need to get now? Old setup was stock 350TBI from 1987. Can I use the stock inline fuel pump? Do I need a pressure regulator? What will I have to do to my tranny (TH700) so it will run right? Any suggestions would be greatly appreciated.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you got a PM
  3. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i'm not sure what pressure the fuel pump you have is rated at, or sure if you can just add a regulator to it? i believe most carbs run at about 6-8 psi (i'm sure someone will correct me if i'm wrong), so you MIGHT (as in maybe), have to change your fuel pump? i've just recently put this same motor in my 85K5, and i dumped my quadrajet, and bought a 625cfm Carter/AFB carb. if your old motor did not have vortec heads, you will have to modify your bracket(s) to work for the throttle cable and TV cable (for the trans.), we did not have to modify anything else for the trans. (700R4). also, since the vortec heads do not have the EGR provision in them, you have to plumb in the exhaust from somewhere. (i can help you out here, if you need help) i got a few responses from some peeps here when i had questions about 2 months ago or so. also, my stock exhaust did not fit, so i had to buy headers (which i was going to do later on), so this was an expense that i did not want right away, and also had to redo my exhaust (instead of modifying it to work, i just ran a new 3 inch single exhaust with a flowmaster muffler and hi-flow cat). that's all i can think of for now, but here's a few pics of my set up (till i get around to cleaning it up later on).
    http://sosaman.home.texas.net/blazer1.jpg
    http://sosaman.home.texas.net/blazer2.jpg
    http://sosaman.home.texas.net/blazer3.jpg
