Got my D60 installed, HELLO DW!
Discussion in 'The Garage' started by txbartman, Mar 2, 2003.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Well, I finally got my 1-ton conversion done enough that I could drive the rig around the block. As things were doing okay, I kept making bigger blocks. Finally, on one side street, I was going around 25 or so (guessing as I haven't hooked up the speedo yet) and started to slow. Dang thing started to shakes and wobble so bad I thought I was loosing a tire!! I slowed down quickly ight in the street and got out to check all four tires. Everything appeared okay. I continued onto the next street. Got up to about 30 or 35 and then went to decel for the next turn and HELLO!! Thought I was gonna loose it!
    Got the rig home and parked it. Went into the house to clean my drawers. Holy snot that was scary!!
    Anywy, on my way to the hardware store tomorrow to try the washer fix. Hope y'all's ingenuity works for me! I am running out of pants!!
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Right on, welcome to the other side.....
    By the way, DW, Sure is fun isnt it /forums/images/graemlins/tongue.gif
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    WTO ram assist, 399....
    -- Mike
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    or 8- 1/2" fender washers...$3
    No more death wobble...priceless /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Been there...ruined a pair of pants. DW sucks!!!
    Rene
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I actually have a WTO setup, just don't have the tabs welded yet for the ram. Was planning to drive it to the welding shop. Need the washers for that!
  6. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    You can have Steve at MOO weld the tabs on the bolt-on ram mounts.
    Dunno how much your welder is charging you, but this may not cost that much more.
    -- Mike
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Hehee, Welcome to the club /forums/images/graemlins/thumb.gif Lucky you did the swap at your house. I installed D60 at a friends shop 30 miles from home. Had to take side streets all the way home, had to slam on the brakes and pull to the side every 2 miles or so. Get that ram on!
  8. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Sheesh, I feel really lucky. I did the Dana 60 front axle swap last fall to my '74 K10, and I haven't had even a hint of death wobble. I'm very meticulous when I work on my truck, and I try to do everything right. I can tell by many of the posts on this site that a lot of guys work in the same manner, trying to get everything just right. It's weird that some wind up with DW, and some don't. /forums/images/graemlins/tongue.gif Well, good luck, it sucks to spend a bunch of time and money to have things turn out not nearly as well as they should...
  9. rtigert
    rtigert Registered Member
    Feb 16, 2003
    14
    Gainesville, Texas
    Re: Got my D60 installed, HELLO DW! *DELETED* *DELETED*
    Post deleted by rtigert
  10. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    OK my D60 is going under the K5 within the week...what causes this DW and what are the washers for?
  11. new2k5
    new2k5 1/2 ton status
    Dec 16, 2002
    128
    south eastern PA
    [/ QUOTE ]ditto
  12. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Here.........
    The cure
  13. rtigert
    Feb 16, 2003
    14
    Gainesville, Texas
    I saw that post but do these spacers only go in the TOP caps (bushings), the bottom caps (bearings), or in both upper/lower???
  14. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The bottom wouldn't need it. They are saying to use them on the top where you have the plastic bushings.
    -- Mike
