Got my new high angle shaft, problems installing it *PICS* *UPDATE*
Discussion in 'The Garage' started by BranndonC, Jun 19, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    So my shaft came today!!!!
    But i cant seem to get the shaft to slide all the way into the slip yoke.... do these pictures look correct?
    I realize the rear isn't even but even if it were 1 inch more in that still wouldnt look right and i didnt want to go to far with the installation. /forums/images/graemlins/1zhelp.gif
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Re: got my new high angle shaft, problems installing it *pics*
    Call Jesse about this issue.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    your sure it's an issue? not my mistake installing it, or maybe it is supposed to be like that? I HAVE to drive 200+ miles saturday to get my 1 ton axles installed and i dont want to make the trip on my front shaft alone /forums/images/graemlins/1zhelp.gif
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    [/ QUOTE ] /forums/images/graemlins/thinking.gif
    It looks like it is not in all the way but call jess he will work with you and help guide you on the proper install for you and work with you if their is a issue /forums/images/graemlins/grin.gif
    Good luck
  5. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    The slip shaft does not look like it is fully seated on the t-case output shaft. Did you grease the female splines on the d-shaft and the male splines on t-case output shaft? Also, although I am not suggesting you do it, have you taken a soft mallet to try and get the d-shaft to slip further down on to the splines on the t-case output shaft. I second calling High Angle about this for suggestions.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks guys, i'll call him now
  7. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Is there a keyed spline? If so, try shifting it one tooth at a time to get it to fit. My original slip yoke had a couple splines missing so you could only put it in one way but you could still get it on a part of the way before it would stop.
    Just an idea...
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yes it is key'd, that might be the issue, i'll check. Also the transfer case might have been damaged when the previous shaft fell off
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Re: got my new high angle shaft, problems installing it ***PICS***
    Probably a wear mark on the spline of the t-case.
    But the dl still looks short.
    Even if the you get the shaft to slide in DO NOT run until you verify with Jess.
    Reasons:
    *It could reach that bind point again and really f something up
    *it looks short to me
  10. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    Reasons:
    <font color="green">Yeah i would check it out before you go any farther... It definitely looks too short to me?
    T </font>
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok guys, here's the update, Then iordered the shaft, i believe the slip yoke from the other shaft was already hanging out about 2 inches or so, in that case i ordered the new shaft too short, but that doesn't explain why i had to hammer out my old shaft and couldn't get the new shaft in, or even get the old slip yoke back on once i hammered it out, so i removed the cover over the shaft from the t-case and all looks good there, maybe the seal is causing resistance? here's some more pics
    Everything looks fine.... /forums/images/graemlins/confused.gif any ideas?
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Is it bottoming in the base of the DL part of the tube?
    Debris?
  13. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    no i can slide it all the way on, but it is sitting in the u-joint spot on the axle where it is supposed to be, so that's how it would sit if i mounted it like that. i know it's too short
  14. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Gotcha.
    Good luck but I am sure Jess will take care of you. Excellent customer support!!!
  15. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    it will probaly be perfect when you put the 14bolt in it
  16. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    But i still have the problem of the shafts not sliding when that little cover piece is over the output shaft from the t-case... i cant do anything while it's like that
  17. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Oh, another wrinkle....
    Will the t-case housing slip over the shaft while it is off of the tcase?
    If ti does you might have bent it when you pretzeled the old DL.....?
  18. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yea the tcase housing that i removed slides over the slip yokes when it's removed, but not on
  19. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ttt
  20. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    When the housing is installed, is the splined shaft centered in the housing???
