Got my new shoes on but have a leak in one tire... need help!
Discussion in 'The Garage' started by MudFrog, Dec 27, 2002.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Do ya'll think fix a flat will fix a pin hole size hole in my sidewall? I got the 37's on but one of the tires loses about 10 psi per hour. Not much of a hole, completely naked to the human eye. We had to pour soapy water on it to find it. Anyway the tire shop said they would not do a radial patch but I should try a couple cans of fix a flat.. any advice? BTW... here is a pic of the new tires.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    looks good with the tires. i personaly hate fix a flat. and if you read on the can it is a temp fix. unless they changed it on me in the last year or so.
    you cn do a patch yourself. get a "boot" from napa. they are for using tubes. you dont have to use a tube, but you can. your choice.
    but know over time you will be doing the atch a few times if you dont. the side wall does see a bit of flex.
    Grant
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    if it is a pin hole, and you cant even see it when inflated, (10PSi an hour is acutally quite a bit btw). I'd dismount the tire, clean the inside where the hole is, and just slather the area with a few layers of rubber cement. (you dont need to use the patch). Should be ok. But if it came that way, you might want to start some beef with the tire dealer.
