got my new stereo installed... but **all fixed**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Sep 17, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i just had my new alpine stereo put in and it works great! but when i turned on the lights, i blew a fuse and i have no instrument panel lighting at all, what happened and how do i fix it? /forums/images/icons/confused.gif /forums/images/icons/frown.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: got my new stereo installed... but
    I'd take it back to the shop and make them fix it. Sounds like they got a wire trapped between 2 parts somewhere and grounded it. Turning on the power blew the fuse.
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Looks like they hooked the Illumination light on the back of the deck wrong. It probably ground the system out when you turned on the lights and that is why it blew the fuse. Try replacing the fuse and un hook the deck and turn on the lights and see if it blows. Hope that makes sense
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    take it back
  5. muddysub
    Jun 23, 2001
    10,452
    489
    ok, i'll call the guy tomorrow, someone told me to look for a bad head light ground, i'll do that too.
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I did that when I hooked up my stereo.. I figured the brown wire was a ground.. It isn't it is for the stock stereo lights.. When you turn on your lights a light in the stereo comes on.. Just found a ground and that fixed the problem..
  7. dyeager535
    26,980
    I'd make them clip out all their added in crap, fix your wires they tampered with, and hand them some accessory plugs from another vehicle, (wrecked, similar vintage GM) so the radio can just be plugged into the fuse panel.
  8. muddysub
    Jun 23, 2001
    10,452
    489
    //update// i have no tail lights either! brake and back up work but no tail lights. /forums/images/icons/mad.gif
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I think that the brake lights have their own fuse, and the tail lights share the fuse that powers the dash.
  10. dyeager535
    26,980
    Get in there, undo everything they have done, and make sure it gets done right.
    If they just messed around behind the radio, then it should be pretty apparent what all is connected to the radio, and what needs to be removed.
  11. muddysub
    Jun 23, 2001
    10,452
    489
    the guy that did the install for me was cool enough to meet me half way across town (he lives like 2 states and a county away! /forums/images/icons/tongue.gif ) and fix it for free. so all is well now. /forums/images/icons/smile.gif
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    So what had he done wrong? /forums/images/icons/wink.gif
  13. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    And if you replace the fuse and turn on your lights POP! When replacing your factory stereo theres an brown wire that goes to yoour head light switch, it looks black but the book says its brown, with your power wire cluster. Disconect it and taped it, theres a SMALL black wire in a different cluster, going to your stereo night lights,connect that wire your ground. replace your fuse and turn it up /forums/images/icons/wink.gif
  14. muddysub
    Jun 23, 2001
    10,452
    489
    that's what he did and it works fine now. /forums/images/icons/smile.gif
