Got my new tires! Go on this weekend with the axles...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jan 28, 2003.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I think they are just right...
    www.lonestar4x4.org/42TSLs.htm
    'Course, then I gotta figure out how to climb into the sucker!
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    whoooa! very nice. /forums/images/graemlins/eek.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those should do a good job of getting you through that North Texas gumbo/gorilla snot. /forums/images/graemlins/eek.gif :thunb:
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Those things are awesome!
  6. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Is there some sawz-all work in your near future?
  7. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    That and hopefully a trash can for those G.D. fender flares. /forums/images/graemlins/thumb.gif
  8. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Bye bye fender flares. Some sawzall, but not too bad. Will add zero rates and move the front axle forward. The flares on going to another in my local club (clint).
    Funny thing, those fender flares worked great offroad. Only time they broke is when I scraped up against my big trash containers at the house!
  9. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Dig them cool excentric rims in the last pic /forums/images/graemlins/grin.gif Looks like something of a Shriner clown car /forums/images/graemlins/blush.gif
  10. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    what size life are you running?
  11. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I assume ou meant lift?!? I am running 4" Rough Country suspension lift with 1" A-Tron axle offsets. I also run a 3" body lift.
    I measured tonight. I should be okay with clearances once I trim the back of the front fender to the tub and to just below the bottom of the inner fender (about 1" below the side marker lamp). But, I'll know in a few days! /forums/images/graemlins/thumb.gif
  12. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I hated mine, and I didn't even have the cut outs like you do. I could not wait to get those things off. I am still catching hell from Jason over those. I seem to always want to run them into trees, and once I took them off, I could see obstacles way better.
  13. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    42's have got to be the perfect tire size /forums/images/graemlins/thumb.gif You might have to do more than a little fender trimming.. depending on your suspension travel. Check out my pics to get an idea of how much I cut to stuff 42's under a 6" lift. It still rubs on the rear inner fender.
  14. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Is yours a true 6"? Is that all the lift you have? Did you move your axle any?
    From your pics, that is the same kind of trimming I plan to do. However, I have a 4" Rough Country lift which is almost 5 true inches. I also run ORD HD front shackles which provide another 1/2" or so. Add to that the 1" A-tTron axle offsets, the fact that I am moving the axle 1.5" forward, and the 3" body lift and I believe I should be okay with comparable trimming.
    You think?
  15. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    what are you goin to do with the flares??? /forums/images/graemlins/wink.gif
  16. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm running 6" ProComp springs in the front which suck pretty bad at flexing. Its a true 6" plus I'm also running the ORD shackles and no body lift no axle relocation. You probably have better articulation than me but with your body lift and moving the axle forward you shouldn't rub in the front with this amount of trimming.
    In the rear I'm running f150 springs with a shackle flip. The axle is moved back 2 inches and the only thing it rubs is the inner wheel tub.
    Post some pics when you get them on.. you're truck is gonna sweet /forums/images/graemlins/thumb.gif
  17. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    ****, your truck is taller than mine on 42's. You could easily put 44's on your truck with all of that lift. Of course, I am a little happier with the sawzall than you. /forums/images/graemlins/thumb.gif
