Got my SYE installed last night
Discussion in 'The Garage' started by zcarczar, Mar 26, 2005.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Pretty easy kit, took forever to clean everything though. I think if I wasnt screwing around so much I could have easily had everything done in 3 hours. But it ended up taking my about 5 or so cause I had to make sure everything was clean, and tight and installed right. Now I just need to order my driveshaft after I get the new rear suspension done.
  2. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    COOL man looks good. Hope to get one myself soon.
    Mike
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Sweet, I wish I had a electric speedo, its just hard finding a 89' 241 :mad:
    Looks sweet though. Is that a strap or u-bolt yoke?? 1350 yoke??
  4. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    pardon my ignorance here but what exactly does the SYE kit do?? what are the advantages of having this kit:confused:
    thanks matt
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    It does a number of things. Gets rid of the slip yoke output which causes vibration and if you ever brake a u-joint you will loose all your fluid with the shaft out. The SYE also will make you rear driveshaft longer which is better for angles.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    looks bling. JB conversions? Any reason you decided not to go with the ultra short one? Just didn't seem worth the extra cost? I know what you mean about taking longer to clean crap and such. I always do that, it often takes me forever to do a simple thing cause of it.
    What are you doing for your rear suspension?
  7. ilikeitloud
    Oct 30, 2003
    134
    ahhhhhhhhhh thanks for the info bro!!!!!!!!!
  8. zcarczar
    Feb 10, 2002
    2,495
    Its 1310 yoke, but will be getting replace with a flange from High angle driveline.
    I wanted to go with a super short SYE but its only available for the drivers drop 241 which kind of sucks. My 89 is a mechanical speedo, and I have all the crap to put it back to mechanical speedo, but im just too lazy to do it.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so why did you get a new t-case??
  10. zcarczar
    Feb 10, 2002
    2,495
    long story, but I broke on the first one when i dropped my front driveline on the street, then i got one from a junkyard, and put that in, but 4 lo didnt work, then i bought another one and thats the one thats in there now. So I have a spare t-case sitting in my garage.
