Got stuck, now almost no forward gears (turbo 350 / np203)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cjk3500, Feb 2, 2003.
  1. cjk3500
    cjk3500 Registered Member
    Sep 10, 2001
    15
    Blairstown, New Jersey
    I got stuck on the side of a snowy hill /forums/images/graemlins/angryfire.gif with my 77 K10 with a turbo 350 and np203. I had all four wheels spinning pretty good and couldn't get up the hill. I went back the next day after the snow had gone down some and it wouldn't even spin the tires anymore. It didn't even seem to load up when I put it in gear. I pulled the truck out with my K3500 /forums/images/graemlins/crewcab.gif but I had no forward or reverse. I checked the fluid and the linkages and everything looks fine. After some moving the shifters back and forth I now have normal reverse, but I have to put it in low gear to even be able to creep forward (with the engine revving pretty high). Any ideas on what happened or what to look for?
    Thanks in advance,
    Chris
  2. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    I'm going to say its probably a burned tranny. Have you checked your fluid? if its brown or black and smells like burning you know its the tranny. I don't think it woul.d be the T-case unless you hear grinding and whatnot, so its most likely the transmission.
  3. Mikeyg79
    Mikeyg79 Registered Member
    Aug 3, 2002
    83
    Sounds like another roasted TH350 to me.
    Gotta love the SM465..
  4. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    i lost 3rd and 4th on my 700r4 in 4H doing mudding
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Another turbo 350 bites the dust. In my opinion they're worse than a 700R4. There's a reason why I have 3 dead TH350s laying around. And I've never run any of them, they were in trucks I bought.
    You've probably got enough smoked clutches to cure a ham.
  6. cjk3500
    Sep 10, 2001
    15
    Thanks for the replies. I checked the fluid again and it is burnt. So much for this truck, It has soo much rust and now a bad trans, any one need a parts truck in NJ? /forums/images/graemlins/wink.gif
