got stuck- steering wheel crooked??
Discussion in 'The Garage' started by fordslayer383, Mar 17, 2005.
    went for a rip today got crazy stuck in the snow now my steering wheel is off when im goin straight- do i need an alignment???
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    mines done that once or twice, usually if i go to full opposite lock, it will straighten out. Say its off to the left, crank it full right and it might fix it. I dont know the actual cause though.
  2. you think that works? i mean today i wasent really reefin on the wheel or anything its just a lil off??
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ive never had mine realigned, or any ill effects from it, just crank it to lock then bring it back to center and its fine. All these trucks are a little different though.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I had a truck that did this and it was a broken leaf spring centering pin. My K20 also does it because of a loose steering box/damged frame. It could be several things, but likely not an alignment issue.
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Its normal. Anytime you do somethin somewhat stressful on the steering it can tweak it a lil. hit a burm, get cross rutted. Just normal wear and tear. Usually a sign of worn parts.
    Mine has done it...shoot my steering wheel is about 20* off CCL :D
  6. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    bent something??
    You probably bent the tie rod slightly or the draglink at the sleeve,or a center bolt in the spring sheared as already suggested...I'd also take a good look at the "rag" joint where the steering box meets the colum,it might have gotten damaged...If you "wounded" a spring and it sags some,it will throw the alignment off too-
    -my trucks steering wheel is about 1/4 turn "off" of center when the weight of my plow flattens the front springs out,then returns to its normal straight ahead position when the plow is removed...I dont think any amount of turning the wheel back and forth will "correct" anything!...if the "straight ahead" position keeps changing,something is definatly loose or broken--the U-bolts or shackles might be loose or bent also....time to go crawl under it and do an autopsy on your truck..I wouldn't drive it until you find the problem--could be dangerous!.:crazy:
  7. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    850
    Pinckney, MI
    This happened in my k5 as well. Seems to still track right but the wheel is off a little. My bro's 94 3/4ton had the same problem but, the gears in the steering box jumped. All we had to do is reseat them and it was all good.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    my stepdad went head on into a large snowbank pack a few winters ago in his 82 k-10 shorty, well it tweaked the steering to one side,
    so whats he go and do, he yanks his steering wheel off and turns it a little and puts it back on...
    i find that to be retarded,
    but he did it,.,.
    and that was it
    nowadays the truck is stripped down to rolling chassis with just bare cab and rad support on it and the drivetrain in it, the rad support mounts are so junk that you can lift the support off the chassis even though the two mount bolts are intact,
    and i swear i can see the frame rails are tweaked more towards one side of truck than other, but i dont have a real way to check for that scientifically,
    good luck
  9. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Check to see if your steering box bolts are loose. All it takes is for one or two to be just a little loose, and the steering wheel can go off center when torqued on.
