Got Terminated
Discussion in 'Rocky Mountain Region' started by Hossbaby50, Jul 24, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just got back from Terminator. I got Terminated.
    It was a really good run till the very end. Mike, Matt, Eli, and myself drove with Shane, Andrew, and andrew uncle. It was a little sketchy at first, since it looked like the weather wasn't going to cooperate. It finally did.
    We ran the trail pretty well. A few hitches but no big deals till the end. Eli got off line in the White line and had to be extracted (no biggy). Matt, Eli, and myself ran Zturn and I had a little power steering issue. Put some fluid in and all good. Ran Zturn about as well as it can be run. Ran the whole rest of the trail very well until the last climb out.
    Eli and Mike made it up. Mike needed to bump it a little bit but got up. I got in and got in a spot apparently and tried to bump it. BAD IDEA. 14bff smacked a rock, front tires hit a ledge as I bumped it (apparently to hard) and the whole truck went 3 feet in the air I am told.
    Came down and BANG...... I initially thought driveshaft. Then I heard the dreaded word FIRE. I jumped out and put it out. I grenaded the rear shaft at the slip yoke. No biggy pop in spare shaft. WRONG. Upon further inspection I DESTROYED the 208. The whole tail housing was broken off and I had NO gear at all. Not even front driveshaft. I couldn't get up the hill because of the rear shaft hanging so I had to be winched down part way to get the shaft out. Then I had to be winched up the hill which was no easy task and it too stacking and some major power from Mike's Warn to get me up. It was a good night that got bad at the end. With everyone's help I finally got out of Terminator and back to the road were I was towed to the parking lot by Mike. Matt took over for the homeward bound duty even though he was having a miss in the motor.
    I am greatly indebted to everyone out there tonight but I especially thank Matt and Mike. They towed my broke ass out of a nasty spot. I thank everyone else to for the help they did. I was totally at there merchy and you all came threw for me. I really appreciate it everyone.
    Harley
  2. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    P.S. there are lots of carnage pics that will be coming soon, and I mean some serious carnage.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    /forums/images/graemlins/yikes.gif
    Ouch... I guess you got the truck home 'eh?
    I got lotta 208 parts.
    Marv
  4. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    /forums/images/graemlins/yikes.gif That had to hurt. At least 208s are cheap and easy to rebuild.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just took apart everything that I broke (that I know of)
    Updated carnage list:
    Rear Driveshaft is distroyed
    Transfer case is trashed
    Both halfs of the case are cracked and broken
    Mainshaft in 208 is bent
    Rear yoke on Dshaft blew and ear off
    Custom 4x4 Iron crossmember is pretty beat. Bent and broken (can be fixed)
    Frame rails are bending where crossmember attaches (started prior to this run though)
    /forums/images/graemlins/crazy.gif
    Pics will be coming soon
    Maybe more later
    Harley
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    After further inspection and reading into the breakage and problems this is the scenario that I have figured out.
    The Tcase is trashed because the driveshaft bottomed out when I came down from the bounce. When it bottomed out it pushed the ass end of the tcase straight up bending the mainshaft and ripping the case open.
    So now I know I will need some good bumpstops. If I would have had bumpstops I would have just had to replace the driveshaft and driven home.
    I guess this is all part of the learning curve of semihardcore offroading. I didn't honestly even think I would need bumpstops in the rear because I am running 4-5" of lift with stock length driveshafts. Apparently I was wrong, really wrong. /forums/images/graemlins/doah.gif
    Harley
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Harley , I have all the internals except the shift forks are bad . I do not have the 27 spline input shaft , its in my truck . Between Marvs parts and mine you can have it fixed asap . Call me if you need any of my original case . Good mainshaft , planetaries , output shaft , case and tailhousing . /forums/images/graemlins/thumb.gif
  8. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    Hey Harley, I made some bumpstop plates this week as part of getting truck ready for the trail. Here is a link to the photos bumpstop plates . Not to sure how well they work yet under heavy load but going over the speed humps down the street worked good. Don't get a harsh landing as when the shocks have bottom out /forums/images/graemlins/ignore.gif
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    where exactly did you get your bumpstops? How much? I need to do something for sure.
    That plate really limits your uptravel doesn't it? Just wondering.
    Harley
  10. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    Got the stops from a member awhile back, this is were I got my engine poly mount Performance Suspension They were cheaper than anyone else in Phx. area. Not sure on the upward travel yet cause the stops have cut opening they will compress quit a bit under load. Going to do a trail run this evening and see how much they compress. /forums/images/graemlins/thumb.gif
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    /forums/images/graemlins/eek.gif Dude /forums/images/graemlins/eek.gif.... You had an interesting time, sorry to hear about the breakage, but better to find out now close to home, than REALLY far away...
    Anyway, there's lot's of help for you here, us AZ boys help each other out /forums/images/graemlins/thumb.gif I have some 208 stuff laying around as well. Hang in there man, It goes along like this for awhile... And then gets worse /forums/images/graemlins/grin.gif
  12. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Harley,
    OUCH, sorry to hear about it... That sucks, been there and done that, not on Terminator, but on Raw Deal, the last out. It's spanked me many of time, let's see here is the list:
    1. TH350 Transmission, broke ears off
    2. 1 Rear Drive Shaft
    3. A complete set of axles, both rears and both fronts, that's 4 axles.
    4. Lot's of body work.
    5. at least 3 tires up there.
    Table Mesa will spank you, but just think how much closer you are getting to Amigo Status, and yes breakage goes towards acheiving final status.
    Let me know if you need any help with anything, I will be glad to help out. Don't have any 208 stuff, never used one.
    Hang in there, like Fred say, it only get's worse! /forums/images/graemlins/smile.gif
    Rob
  13. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Sorry to hear about the carnage /forums/images/graemlins/yikes.gif, but it sounds like you couldnt ask for a better group to cover your back. /forums/images/graemlins/thumb.gif Thats what I like about this group /forums/images/graemlins/woot.gif
    BTW are you gonna go 208 again for the gearing or upgrade to 205 for strenght? I know a guy who had a 205 for $80 last month. It was a 27 spline version and he had the adapter for a little extra.
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pics of the Carnage
    [image]http://coloradok5.com/photos/showphoto.php?photo=13964&password=0&sort=1&cat=500&page=1[/image]
    [image]http://coloradok5.com/photos/showphoto.php?photo=13962&password=0&sort=1&size=medium&cat=500&page=1[/image]
    [image]http://coloradok5.com/photos/showphoto.php?photo=13961&password=0&sort=1&size=medium&cat=500&page=1[/image]
    [image]http://coloradok5.com/photos/showphoto.php?photo=13960&password=0&sort=1&size=medium&cat=500&page=1[/image]
    Harley
  15. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    We met a TM near 9pm, I got home a bit after 5am.
    Ya it was eventful to say the least. Clean run up to the exit. I smacked that Z-turn w/o a spotter no hangups or nothin. I did manage to tear a t-case x-member bolt through the frame. (stupid spacers /forums/images/graemlins/angryfire.gif) Oh well I will just plate it, weld it, try to break it again /forums/images/graemlins/peace.gif. I sure did have a blast though. To bad for your rig harley. Just add it to the to-do list /forums/images/graemlins/deal.gif
    Got my miss fixed -> shot spark plug. This motor burns so much oil I am thinking of converting to friggin' glow plugs /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I was behind Jay last night on fr42 after work , sure did not hinder his flex at all , that truck was a beast last night . A little uptravel removed sure , but I couldn't tell /forums/images/graemlins/thumb.gif
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Fixed the pic's for ya dude...sucks!
    I'd upgrade to a 205 with fixed yoke.
    Rene
  18. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Harley,
    Are you sure the trannys ok?
    You know.... it may be kinda good that you had a 208!... If you'da had an iron case, it woulda trashed the tranny for sure.... /forums/images/graemlins/frown.gif
    Marv
  19. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Damn, that looks semi-simlar to my case, except I broke my case in half. Front driveshaft u-joint broke at the pinion and I didnt feel like pulling the shaft out so I bungee corded it up(stupid idea). Well it fell out and when I was going over some rail road tracks the driveshaft fell out and hit the ground and broke the case, front driveshaft, tweaked the frame and cross member. I dont think my trans got hurt. But I finally found out what was making the horrible noise in my t-case. It was the low range shift fork.
  20. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not sure 100% that the trans is ok we will see. I checked it out today and I can't see any cracks in the case and the output shaft spins when you put it in gear. I hope the trans isn't trash otherwise it will be a long downtime since I am not going to spend another $1600 on a 700R4. Mine is still under warranty so if it failed internally I might be able to get it fixed under warrranty. /forums/images/graemlins/dunno.gif
    I will find out as soon as I piece together a new tcase and get my truck driveable again. Even if it does do ok I won't be wheeling again till I can get a new driveshaft, crossmember reinforced, and bumpstops.
    Harley
