Got the 56" rear today BUT..... FIXED Thanks guys!
Discussion in 'The Garage' started by RingMaster4x4, May 21, 2004.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Got the 56\" rear today BUT..... FIXED Thanks guys!
    ok well I got the 56" rears today and now the shackle goes back to the point of being flat. That Is not good either is it? /forums/images/graemlins/dunno.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Got the 56\" rear today BUT.....
    quite bad. What setup are you using? If I went with 56s I'd run a 2" longer shackle(nice low rider shackles) and turn ORD flips around so they pushed the mounting location back isntead of forward. That would be a good setup as far as shackle angle is concerned.
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    ok I just snaped a couple of pictures I will post the in just a few min.
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    ok here is one
  5. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    when I installed my 56's I moved the spring hanger back from stock. I measured eye to eye along the spring (mine were stock so it was a true 56... lifted springs will be a bit longer to account for the extra arch) so I set the hanger such that the distance from the front hanger bolt to the rear shackle bolt, with the shackle laid back flat, was 57 inches. This will keep the shackle from ever laying back flat even when the spring is flat.
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Is there any way to get this fixed with out moving the spring hanger?
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    If you use the 2" drop shackle (for low riders) its will give you more lift and push the spring down
  8. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    so a longer shackle should help?
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    help but I really really think you need to move the mount. I know with your tube frame that will be a little more difficult. How long is that shackle? Doesn't look 4".
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I think that it is a 4" shackle. I will check
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    would look like this
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if it is stock its 4". Shackle will help but like I said you should really move the mount. 45 degrees is a much better shackle angle but not really perfect in my mind.
  13. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yep it's a 4"
  14. micah
    Sep 18, 2003
    374
    Austin, TX
    did you measure along the spring? measure as if the spring is laid flat with no arch. as for fixing without moving the hanger... if you go with a longer shackle, you could fix it... but new issues could be introduced... such as too much lift, and something lower to hang on as you drop off a ledge, etc....
  15. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I see what you are saying but I need a quick fix if that will do it for now that is what I am going to do. I will try to get the hanger move later. Thanks for all the help guys. This kind of help is what makes this place great. /forums/images/graemlins/bow.gif /forums/images/graemlins/waytogo.gif
  16. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i had the same thing happen,and i thought i could solve it with a longer shackle.....it didnt work....i moved the rear hanger back 2" and made a 6" shackle and all is well...
  17. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Not good to hear. I guess I will talk to the man that made the frame and see what he says. /forums/images/graemlins/thinking.gif
  18. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Thanks guys the longer shackle worked great. /forums/images/graemlins/waytogo.gif now I need to get some zero rates to move the axle back and bring the front up so I don't have such a huge rack (about 4" /forums/images/graemlins/blush.gif). I will post some pics tomorrow.
  19. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Thats why most of the 56-57" flips come with a 6" shackle /forums/images/graemlins/deal.gif
