Got the beast stuck on a main road
Discussion in 'The Garage' started by adamforsythe, Dec 19, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Around 11:00PM last night I was leaving my friends house and I got stuck in is drive way it took me 45MIN to get her 40 feet if that (ICE SUCKS). My damn T-case is crapping the bed hard. My 4x4 did not work. Well when I got it out I went and dropped another one of my friends off and the damn 4x4 worked.
    I have know about my T-case $#!&^%& the bed for awhile. It would kick out of gear and grind.
    Ever since I got my K5 stuck up to the doors in mud in a swamp my T-case has been real bad. Now when the truck kicks out of gear it is hard. I mean it moves the truck hard.
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    What do you mean it moves the truck hard?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sounds like you got a bit of dirt and muck in your tcase. Might already be fubared.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I got stuck on my driveway with ice and 5" of snow last weekend. But I was just in 2wd and BALD tires. A little more skinny pedal and she was out! :D
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    You can fill the T-case kick out of gear. When it does it sounds like someone hitting the T-case with a hammer.
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    This has happened to me on a few occasions. In my case I just had to adjust the shift linkage for the t case. disconect the linkage and manually shift the t-case from under the truck into whatever range it is popping out of. If it doesn't pop out when the linkage is disconected then you just need to adjust it.
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I will try that.
    ADam
