got the cab stripped!
Discussion in 'The Garage' started by rubbinz raczn, Jan 31, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    over the weekend i finished ripping all the wiring dash etc from the 85 chevy. i decided since i wanted a in cab cage done right the dash was in the way. so it's gone. i also cut away any wiring that would not be used.today i degreased the frame and firewall. tomorrow i am playing hookey from work and welding up the firewall holes. also hopefully getting the frame painted flat black. gotta jack it up up and pull front-rear mounts- springs etc. hopefully get the suspension finished. still waiting on t-case and doubler adapter from NWF so if thatr shows soon i can install engine-tranny-t-case-fab shock mounts etc.
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    what combo are you doing with your doubler, more specifically, what tranny?? going to man up and put a 4sp in there???:D
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    i have been torn about which tranny to go with! i was thinking about using a th350 trans. the engine will be a stock rebuild type 77 chevy 350 with a cam-holley intake-lunati cam-holley truck avenger carb. i have the th350 but want to do it right even if i gotta do another tranny:D
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    damn, your a fast worker! 'should come down her and kick me to get me motivated... :grin:
    Looking good!!
  5. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i need some motivation as well. its taken me 2 weeks to get the front clip off the blazer.
  6. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Hey that looks familiar!!
    Not as clean as yours, but along the same lines.
    Except mine came off the frame now.:D
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    steve the the main thing about working on any rig is, keep mind of the way it comes apart the same goes for putting it back :D
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL if I need any help putting something back together, I will ask you since you did this not too long ago:)
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    good advice for ya there steve. when i tore mine down, i had 3 best friends. masking tape, a marker, and ziplock bags.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I started doing that half way through, when I started it was a race again the weather and time to get it apart...
  11. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Take lots of pictures :D I do
  12. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    good point! don't be afraid to mark and tag everything. even if you think you will remember. if someone else helps you make sure they do cause if you didn't take the part off you may not no what it is or where it came from :D
  13. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    is that the new axle trend now (lawnmower)
  14. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    got the firewall holes welded up. frame primed and painted :D
  15. Esteban86K5
    3,712
    Bakersfield, CA
    WOW. Looks good.
  16. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    what did you use to clean and paint the frame with, that looks really good
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lookin' good lonnie!!
  18. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    lookin good
  19. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    first it got degreased, then makita with a wire brush then laquer thinner with a scotchbrite, then castrol superclean! i used etching primer in a rattle can then flat black. not sure how it's gonna wear but it don't gotta be purdy!:pimp:
  20. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
    I am in the process of putting my 73 back togeather after a complette tear down. Does any have some pictures of where the floor meets the rockers? The PO did a hack patch job there and I need to see what it looked like stock. I have fabed up some heavy inner rockers and am getting ready to rebuild the floor. I will shot some pictures of the inner rockers this weekend and post them.
