Got the Echobit shackle flip - but is my rear end still too low?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 5, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I got the Echobit shackle flip on. It is supposed to be something like 5 3/4" lift. I removed my 4" lift blocks at the same time.
    Here's a pic:
    Pic of shackle - 65k
    Looks good and certainly raises it up more to level.
    But as I stood there looking at it, it still looks a LITTLE low in the rear...or does it?
    I have to get some axle shims to bring the pinion down a little, so that should add like maybe 5/8" rear lift.
    What do you think, am I imagining it being low?
    pic of truck - 20k
    another pic of truck - 20k
    -- Mike
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    looks level to me, does your driveway have a slant at all, making it look lower in the back to you?
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Yeah, my driveway does have a slant. I need to park it on the street and look at it then.
    I blame it on being tired after working on the truck almost all day. /forums/images/graemlins/wink.gif Thanks.
    -- Mike
  4. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Looks good to me, let us know how it works. /forums/images/graemlins/thumb.gif
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    It looks level to me but then what the hell do I know. I would run it around the block them park it some where flat then see what it looks like.
    Eric
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If you follow the body lines, the front wheel well and rear well are not equal, the rear well opening sits lower on the body line and can give the illusion of sitting lower, even if the rear is higher. It looks like it worked out well and sits level. Your shims will raise you another 1/2". As Highlander said, give it a run around the block and flex it up a little, then park it. It most likely wont sit any different since your using greasable bushings all around! It didnt' take all day to install them, did it?
    By the way, that things a monster! /forums/images/graemlins/thumb.gif Can't wait to see pics of it in action.. nearly as long as a burb!
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Oh no, sorry, i guess that was kind of misleading. It probably took 1 1/2 hours to install the flip and remove the old blocks.
    I spent all day working on the truck, however, doing other things and making runs to the hardware store etc.
    I think with the shim installed it will raise it up just slightly and will sit just about perfectly with just a slight rake.
    -- Mike
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok i gatta ask sorry..but what are shims and what do they do? /forums/images/graemlins/blush.gif
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Shims are like short lift blocks, but with an angle milled onto the top of them.
    When installed between the axle and the leaf spring, they would logically cause the pinion angle to decrease (or increase depending on which way you installed them.
    They are used to crrect driveshaft angles.
    Here's a pic of a shim with an 8 degree angle to it.
    -- Mike
  10. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    just use a tape measure and measure the top of the wheel well to the ground on the front and back. /forums/images/graemlins/thumb.gif
    that way your slanted drive way wont play tricks on your eyes /forums/images/graemlins/eek.gif
  11. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Thats a good shackel flip idea. It seams alot easier and more economical then cutting the rivits and installing a new shackel bracket. Where did you get that one? Does it put too much stress on the original shackel bracket?
    How much total lift do you have on the truck? Looks to be more then 4"
  12. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    it looks absolutly awesome. and the site says it gives you 5"s +. heres the link: shackel flip
  13. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I think it's a great idea.
    It's made by Echobit - someone on this post made a clicky for it.
    I don't think it puts excess stress in any way. Included is a 3" steel spacer that goes where your shackle went originally. WHen you torque the bolt down, it crimps the space in place and is very rigid.
    The shackle flip in and of itself is 5 3/4" lift.
    On my truck I have approx. 7" susp. lift front and rear.
    -- Mike
