got the front diff cover on. Now I got a nice spot to mount a ram
Discussion in 'The Garage' started by cybrfire, Jun 5, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Should be able to mount my steering ram on their pretty nicely.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    on that wimpy thing? /forums/images/graemlins/rotfl.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats sweet, you probably doubled its capacity. what did you use 1/4", 5/16"? /forums/images/graemlins/thinking.gif
  4. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    all 5/16" thick. I thought about laying it in the drive way and smokin' it with a sledge but nah. I'll let the rocks have at it first.
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Looks good. Gonna make one for the 14? You could have sent it over to the guy that blew himself up making fireworks. /forums/images/graemlins/shocked.gif Realy put it to the test. /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Quick question Kert.
    How much room do you have between the cover and the tie rod? /forums/images/graemlins/thinking.gif
  7. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Are you going to mount the ram to the diffcover??
  8. CK5
    May 19, 1999
    21,626
    702
    CO
    Don't mount the ram to your cover, unless you want to change the gasket after every tuff trail, ask me how I know. /forums/images/graemlins/whistling.gif
  9. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    finished the one for the 14 bolt today. Matches nicely.
    As far as room between the tie rod and cover there is about an inch. but not really sure I got that goofy ford tie rod on the right way. Its just temporary in my case so I didn't pay much attention to it.
    I was gona mount the ram to the cover but now it sounds like that is not a good plan. The ram must have enough power to slip the cover on the gasket and cause leaks?
    I can still mount the ram above the cover. either way its all good. Happy with the new cover thus far.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you plan on going histeer? when you turn the wheels the tierod will move back, not sure how much, but it may hit the cover /forums/images/graemlins/thinking.gif
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, you will have trouble with the tie rod and mounting on the cover. Several have had trouble with the cover mount causing leaks. And the Ford knucks have the tierod mounted much closer than GMs. In fact, it's so close that you can't use a tie rod of larger than 1.5" OD. I built one for a friends truck and the 1.5" OD touches the stock cover at lock. No room to plate the cover, and no room to sleeve the tie rod for a 1.75 like mine (which I had intended to do).
    Edit: Best thing at this point might be a set of Deden Bear's if you can stand the $$$. Otherwise I think you will want to redo the cover. High steer on Ford knucks is a very bad option. GMs are border line, Fords are well over the line IMO. My Ford buddy has broken several Ford knucks without even hydraulic assist and without high steer. High steer loads the knucks in a very bad way right where the Ford knucks are weakest (noticeably thinner than the GMs).
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...Are you still using the Avalanche rock ring???
    I know when I bought mine from You...
    You were high on the idea...
    I had to spray High-tac spray sealer on the cover gasket...
    to stop my leaking..and re-torque the bolts...after a run..
  13. CK5
    May 19, 1999
    21,626
    702
    CO
    Yeah, still using the rock ring which is holding up fine (except for the ram causing leaks), the problem is the MOO front crossmember which I went to so I could use a straight draglink once apon a time, it is now in the way for putting the ram where I want it so it has to stay on the rock ring until I change the crossmember setup, always something. /forums/images/graemlins/thinking.gif
  14. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I hear yah...it never ends..
    Did you try silicone???
    I saturated the gasket with Permatex's High-Tac spray..
    and I haven't had a problem yet...after 5 runs...
    I was running 44's yesterday.. /forums/images/graemlins/wink.gif
  15. CK5
    May 19, 1999
    21,626
    702
    CO
    I'll give that a try, I want to open it up an inspect it anyway when I remove the busted inner and outer shafts. /forums/images/graemlins/whistling.gif
  16. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Ouch!!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  17. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    the matching rear.
