got the lift on.. pics inside
Discussion in 'The Garage' started by 78Suburban, Jul 8, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I can have some better pics later on, me and my GF went horseriding and forgot to take pics in the daylight, but she has an awsome flash on her camera.
    gotta stay hydrated... I've KILLED a big bag of popsicles during this lift :laugh:
    Now I just have to set up my shocks, brake lines, steering arm, change my rag joint seal, bolt the driveshaft back up, tighten everything down, and I'll be good to go :D
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Looks good, but it would look better muddy!!:D
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Thanks.. Those heavy duty shackles look really good :bow:
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    right on man!
  5. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    100% better, now get some 10" rims and those tires will fill out the wheel wells a little better
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    how big did you go?
    looks good
  7. NoReGrEtS
    Nov 7, 2005
    848
    nice to see that your not smashed from it falling off your wooden rig you had going on:D
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    4" front Rough country springs with 1" zero rates... rear echobit flip (5.5" of lift)...
    when I actually measured it, the front gained 7" over the stock saggy springs :eek1:
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Looks good!
    For brake lines, are you going braided stainless steal or just extending the hard lines?
  10. NoReGrEtS
    Nov 7, 2005
    848
    would you mind taking a measurement for me? when you have some day light
    I need to know what it is center axle to center axle F/R
    thanks
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    27" up front, 26" out back. That's from center axle to bottom of fender lip. Keep in mind burbs are cut lowers in the back, so it doesn't actually have a saggy butt, you have to look along the bottom of the body line under the doors, its actually level. Now if I ever get a Dana 60 up front, that will make the front sit another inch higher, then I would have to get a zero rate out back.
    Also, the passenger front sits 27 3/4"!! the same side sat higher before the lift... I thought it was unequal spring wear... maybe a bent frame :crazy: oh well, I'm gonna drive it lilke I stole it, its all good :D
  12. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    i wouldn't go any wider than 8", other wise you start looking like one of those lowered mexican cars with wider rims than tires.
  13. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    more pic whoring!!!!!
    took two pics in the daylight..
  14. 4xcrazy
    Oct 31, 2003
    9,472
    5
    what size were those tires again???
  15. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    33x12.50x16.5 on stock 16.5x6.75" steel wheels
  16. 4xcrazy
    Oct 31, 2003
    9,472
    5
    oh boy,,,,16.5's
    i have a set of 16.5's here, with alittle better width and backspacing, but i need to find some regular 16's before i parts with them.
    you've seem them, they are on the 81:p:
  17. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    those perdy aluminum ones? whats the width and backspacing?? I wish I had the $$ to step up to some beadlocks, but that may be a while :o
  18. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    sweet man. good work!
  19. 4xcrazy
    Oct 31, 2003
    9,472
    5
    uh,,,no, the black steelies that are on the 2wd
