Got the MTRs mounted (pics added)
Discussion in 'The Garage' started by sandawgk5, Dec 20, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Well thanks for all of the input. All of the places around here wanted atleast $10 a tire cause they are 37s and discount qouted me $25 cause they were gonna put balance beads in:eek1: (which I already had purchased). So for the price of valve stems and a can of WD40 (about $12 total) I mounted all 5 in about 2 hours with the factory tire iron:D . That time includes bead seating and air up. I removed the valve cores and set them on a bucket and used my little MV-50 compressor. With the engine running and no valve core it took about 6 mins to seat the bead and air up to 30#. Only damage is a little scratched paint on the rim (gives it that authentic wheeled look for when I cruise the mall:haha: .) 11 inches of side wall on each side def helped along with the WD40 as bead lube.
    Thanks again
    Ira
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Lets see some pics. I am thinking of putting 37x15 MTR's on my K5. In fact I oredered the beadlocks today :pimp::D:pimp:
  3. sandawgk5
    Oct 28, 2003
    6,881
    Dont have them on the truck yet only mounted on the rims I can get pics tomorrow since it is dark here now. I mounted them on 15X8 wagon wheels that I spray painted flat black.
    Ira
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Want to see them on, off, and width - whatever you can get.
    I really like the 315/75R16 MTR's I have now as far as traction goes. I was not crazy about them being 34" tires tho. 37s required new wheels and I will be doing a bit of grinding on the calipers but there will be many payoffs with number 1 being cheaper tires.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    yeah post up some picture when you have a chance. And if you can get a messurement on how tall the messure on your rig 2 that would be great. I'm going to be needing new tires soon and not sure wether to get the 37" MTR's or 37" toyo mtr
  6. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    yeah pics and specs I'm wanting to upgrade to 37's too:D
  7. sandawgk5
    Oct 28, 2003
    6,881
    I will get pics of them off the truck as well as measurments and a weight if need be. When Roz and I get my 1 tons in I will get measurements and pics with weight on them.
    Ira​
  8. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Mine measure pretty much spot on 36" on 15x8 wheels @ 28psi, that's brand new.
    Here's a pic, because I like posting them.
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks man. looks great :D or those 15's or 17's?
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The exact same tires, literally :) Hope you have fun with them Ira...
  11. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    For future reference, don't use WD40 on rubber compounds-it tends to break them down prematurely. Your local auto parts store has a can of spray silicone that is much better suited to lubricating rubber products--grommets, tires, valve stems, etc... Also much more slippery than WD40.
    Jimbo
  12. sandawgk5
    Oct 28, 2003
    6,881
    Did not think of that I have a can of silicone lubricant in my cabinet as we speak:doah: .
    Ira
  13. sandawgk5
    Oct 28, 2003
    6,881
    Here are some pictures of the tires. They measure 36.5" actual height and 12 13/16" sidewall to sidewall with no weight and 30# of air. All measurements are on a 15X8 rim.
    Do you think I need to trim?:D
    This is your standard city trash can if that gives you a size perspective.
    Here are some comparison shots of the tires I have on now. This is a 31X10.5 on a 15X8? factory rally wheel.
    That is all I have for now. I also discovered that the factory spare tire holder on the tailgate will not work as it is currently arranged. The 37 hits the bumper and the pole to set the tire on is barely long enough to take the weight of the tire. I guess I need to figure a new mount as I do not have the money for one of Kerts bumpers. Prolly just lay the spare in the back until I figure it out. If anyone has any ideas let me know. My current rear bumper is 1/4 wall 2X4 tube just like the ends of my front bumper in the first picture.
    Ira
