Got the new edelbrock on and have a few questions..
Discussion in 'The Garage' started by NITRO, Jan 4, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    it is running rich and loading up a little bit. so, instead of getting a fuel regualtor, can i just buy the offroad kit for it and skip on the regulator? or do i hafta buy a regulator?i will b gettin the offroad kit, just hafta wait for some more money
    NITRO
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    More info pls... what carb (I'm assuming its a carb we are talking about) are you running now?
    -Dan
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I hope your not talking about the Performer series carb? Cause if you are neither the off road kit and or a regulator will help. They suck for inclines or sidehilling. I tried both and when I spoke with a rep from Edelbrock all he could say was that the carb was never intended for offroad use and when I asked why they had an offroad kit he didn't say anything and ended the phone conversation. After a year of my engine choking in all the wrong places it came off and strait into the trash can.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Those do run rich... That is why I bought the needle and jet set with mine.. Like I said the kit is about $90.00 but you get 6 diffrent needle sets and 6 diffrent jet sets.. They are really easy to swap.. Then just find the set that runs good with your engine..
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    hey gokartergo, i wished u lived closer to help me tune this thing. do u have a fuel regulator? im gonna get a regulator and the offroad kit then go from there. but i dont have the money right now to spend $90 for the jet kit. so ill get it the best i can tomorrow.or just take it to a shop and let them use the vacum gauge on it
    NITRO
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    mine runs fine in all situations.i have the off road kit in it and it runs great.i have had it flood a couple of times but i was giving it too much gas and was in too high a gear to get moving and the engine flooded it self.i just floor it to clean out the extra fuel when starting it and it cranks right up after a couple of turns of the starter.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    No I didn't put the regulator on it..I am buy no means a carb guy. It is just this one I can understand a little...LOL
  8. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i got all my problems solved, my plugs were gas fouled and after i replaced those, i adjusted the idle screws 2 turns out and it runs like a champ.
    NITRO
  9. Storm Trooper
    Nov 24, 2000
    4,640
    You still need to look in the book on setting it up. There are many things to check and a chart for sellecting the right needles and seats for it. You should have checked the floats before install if you didn't. As for a fuel reg., you don't need one if your fuel pressure is at 5lbs.
    My fuel pump does 45 lbs. so I had to install a regulator but I doubt you do. Run it for a while and check the plugs.
    If you need a hand, just ask. /forums/images/graemlins/smile.gif
  10. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    understand it. perfect it. make it so. http://www.edelbrock.com/automotive/eps_intro.html
    Never got mine to work off road but that's because I didn't want to purchase the off-road kit and jet package. (wait we had this conversation already, huh /forums/images/graemlins/laugh.gif )
